Steering Damper for 2WD - What do they do? Are They Needed?
My truck did not come with a factory steering damper. I have a few questions related to dampers.
1. Are they for use primarily on 4WD trucks?
2. What do they do?
3. Is one needed on a 2WD truck (primary truck use: towing, dirt/gravel roads, bad pot holes everywhere in my town, etc.)?
NOTE: I found a NEW OEM kit on ebay for $100: NEW OEM FRONT SUSPENSION DAMPER KIT 1999-04 FORD F250 F350 SD 4X2 #F81Z-3E650-AA
Thanks!
2. What do they do?
Thanks!
I bought one for my 01 PSD a few months ago. I was replacing my replacement Monroes all the way around with Monroe Magnums, and I thought what the heck why not get the steering damper.
So I bought that kit off E-Bay and had it installed.
I had one put on my 92 Explorer 4wd many years ago, and I liked how it seemed to absorb the steering jolts.
I understand how it absorbs the shock of quick jolts of steering wheel during off road use......but does the damper tighten up steering wheel during right/left normal steering wheel turns...typical street/hwy driving? In other words, is steering wheel slightly more difficult to turn after installed?
Lets see some pictures when you get it installed then. As LOOnatic said some of the 2wd trucks did come with them stock...I had heard that before also. Probably on the higher trim models. I know Bilstein makes an upgraded one.
https://www.riffraffdiesel.com/bilstein-5100-series-steering-damper-2wd/
Oddly enough my truck is a base model XL truck but it came with "heavy service " front end package and i think thats why it came it. I have seen xlt and lariats without it so not sure Fords logic.
https://rover.ebay.com/rover/0/0/0?m...2F281628492328
If this is the same listing you posted up top, it WILL fit your truck.
