Death Wobble cause?
Thanks Jim...
Caster is a 2 way street. Too much positive or negative caster can induce DW. Motorcycle builders deal with this in the builds. I had 32 degrees positive caster on my Harley and low air pressure in the front tire would bring on DW. You will see some bikes with steering stabilizers on the front forks. The reason why Ford is recommending that is because as you go back 0 degrees the wheel/tire begins to stabilize.
Jim
Negative castor is what you find on shopping carts at Walmart etc.
As you can see in the pic, caster either positive or negative to much all equals DW, even if everything else is right
I can solve DW and trust me it was a hard learning process. I got DW, so I stopped in a shop, they said do this, another one said do that, others said just adjust the caster and it went on and on. Sometimes the suggestion helped but mostly it go worse, so bad in fact I could not longer drive it, any speed over about 5 mph and DW just exploded.
So I crawled under my rig and I laid there looking at my suspension, not sure how many hours and how man sketches on paper I made, but my goal was not just to understand how my suspension worked, but how it interacted with each component. Then after a lot of experimentation I began to understand why and with that came how to fix.
For sure, maybe this will help.
It is the stabilizing force resulting from "trail" that counters the oscillation that is DW. DW occurs when the force of the oscillation becomes greater than the stabilizing force of "trail".
Ever see a shopping cart that has one front caster that wobbles crazily when you push the cart? That's the exact same thing as DW.
Yes and no: IF you are OEM and DW occurs, my first advice is alignment and tire rotate, balance and door jam air pressure, if that does not cure it then it's something else besides caster, wheels/tires etc.
In my previous post it was caster that caused DW and in this case it was too much.
That said any component can play a part DW but some are more active than others such as the Track bar, Steering stabilizer and alignment/tires/wheels.
I have cured death wobble on many a vehicle especially jeeps. Used to build custom suspensions, not bolt on... from scratch builds
worn track bar, worn tie rods, having the vehicle (toe in) too high, too little caster can all cause death wobble. the system must work in harmony
death wobble on a brand new truck would be odd but it is possible
on a brand new truck i would look at toe and caster first.
to answer a previous question, the OEM sets the caster at the ragged edge of just enough because it makes the vehicle turn easier, more caster will make a heavier steering feel , the return to center will be a bit lazier and it will increase the turning radius of the vehicle. we used to build massive jeeps with 7 degrees of caster, they did not have the turning radius of a stock caster jeep, but you could take you hand off the wheel at any speed without fear of any movement.
my 2000 f250 7.3 and my 2005 excursion v10 were both set at 5 degrees of caster, guaranteed they took the road straighter than most other fords, I have not had my 2010 f350 for more than a couple months but i can feel a few things up front that i do not like. Ill go through it this next month or so.
frdf250
03-14-2024 06:24 PM
Buyerz
03-19-2017 11:20 PM
