E4od problem - Ford Truck Enthusiasts Forums
E4od problem
Old 12-15-2018, 10:33 AM
bashby's Avatar
bashby
bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
E4od problem
Just obtained a mechanics special 05 E350 PSD. The PO had a problem where after driving several miles, it would shift out of overdrive, then down to second and stay there. He would pull over, shut it off, restart and it would work fine again.
He had it in the shop to fix it when a new problem came up. Its missing really bad, like running on 4 cyls. They told him it needed a big list of parts, injectors, harness, comp., etc. I think its just the VC gaskets and harness, which I have not replaced yet, so I have not been able to drive it yet to experience the trans problem. Assuming the running problem is an easy fix, where do I start with the trans problem? I have an ELM327 code reader and the torque app. He never said anything about the OD light flashing, and I didnt think to veryfy if the light works or not.
Old 12-15-2018, 10:35 AM
bashby's Avatar
bashby
bashby is offline
Tried to edit my post...its a 95, not an 05
Old 12-15-2018, 12:25 PM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like a plug problem on the passenger side of the transmission.
Take the back off the plug and check the wires going into it.
Old 12-15-2018, 12:29 PM
F350 1990's Avatar
F350 1990
F350 1990 is offline
F350 1990 is gaining momentum as a positive member of FTE.
Does the vehicle actually have an OBD2? Many of the heavier GVWR vehicles didn't get those until later..................
Old 12-15-2018, 01:02 PM
bashby's Avatar
bashby
bashby is offline
It does have an Obd2 connector. I was only able to get limited info and it showed no pending codes, which I thought was wierd as bad as it was running.
Old 12-15-2018, 01:03 PM
bashby's Avatar
bashby
bashby is offline
​​​​​​​if there is a problem there is the fix to splice in a new connector or repair whats there?
Old 12-15-2018, 01:27 PM
subford's Avatar
subford
subford is offline
Replace the connector as a pig tail. Splice the pigtail to the harness.
Old 12-15-2018, 04:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
From his later post it is a 1995 . No 1995 E-Series had OBD-II.
Old 12-15-2018, 05:28 PM
bashby's Avatar
bashby
bashby is offline
Well, it has an obd2 adapter that I plugged my Elm 327 into and it connected. I got almost no info but what I did get didnt seem right, and the title and VIN indicate that it is a 95. What year did they start with Obd2 in the e350s?
Old 12-15-2018, 05:43 PM
subford's Avatar
subford
subford is offline
Note that this is an 1995 7.3L.
So no OBD-I or OBD-2.
It is an odd OBD but I do not know what they called it.
It does use the connector plug under the dash that looks like an OBD-II plug.
It does not use the OBD-II error code charts. It has its own set.
Old 12-15-2018, 06:09 PM
bashby's Avatar
bashby
bashby is offline
Does that mean I have an oddball that is impossible to get codes and data from?
Old 12-15-2018, 09:54 PM
subford's Avatar
subford
subford is offline
No there are readers that can read the codes and the code table are available.
Old 12-16-2018, 08:37 AM
bashby's Avatar
bashby
bashby is offline
Thanks for sharing that. So now the obvious question is, How do I retrieve codes?
Old 12-16-2018, 09:49 AM
subford's Avatar
subford
subford is offline
There is a lot of reader out there that will read the codes for your 1995 PSD.
You will just have to check out what reader will work.
The Ford dealers use the New Generation Star Scan tool.
The scan tool must be connected to the Data Link Connector (DLC) for communication between the vehicle computers and the scan tool. If the New Generation Star (NGS) scan tool is used to communicate with the vehicle, an adapter cable must be connected to the tool. Refer to the NGS owner's manual or manufacturer's manual for specific information.
NOTE:
The DLC is located under the instrument panel.
New Generation Star (NGS) Scan Tool
Key off.
Verify that the proper memory (EPROM) card is inserted in the NGS.
Connect DLC cable adapter to the NGS.
Connect NGS DLC cable adapter securely into the vehicle DLC.
Connect the NGS power supply cable to vehicle battery power supply through cigarette lighter, at the vehicle battery with alligator clip adapter, at the dashboard power point or into the pigtail power connector attached to the DLC connector cable.
Turn ignition key to the on position or start vehicle if necessary. The NGS is ready to communicate with vehicle computers.
Follow instructions on the tool or in the diagnostic manual.
To disconnect tool, turn ignition key to the off position and disconnect scan tool from DLC and power supply.
Generic Scan Tool
Refer to Scan Tool manufacturer's manual for specific cables and/or adapters required for Scan Tool hookup.
Old 12-17-2018, 08:02 PM
TimothyOnline's Avatar
TimothyOnline
TimothyOnline is offline
TimothyOnline is starting off with a positive reputation.
Every Ford dealer with which I've dealt has switched to the Integrated Diagnostic System, having thrown the Hickok NGS away 12 years ago.
Ford's iteration of OBD/OBD-I for 1995 is EEC-IV, whose connector (at least, on the low-GVWR vans like mine) can be found between the engine battery and the LH fender. It consists of a six-sided connector and a small extra square connector.
That one may be a dummy. Look for the EEC-IV one under the hood.
Assuming your van is EEC-IV (OBD / OBD-I), theoretically any shop with a scanner supporting older cars (i.e., 1981-1995) should have no problem pulling codes on it. If you want to strike out on your own and buy your own scanner, you have several options:
  • Hickok NGS (eBay)
  • Snap-On SOLUS Pro w/ FORD-1A adapter (eBay)
    NOTE: If you have 4WABS, pick up a FORD-4 adapter while you're at it
  • Snap-On MT2500 w/ FORD-1A adapter (eBay)
  • Any other technician-grade scanner from that time period
  • Innova 3145 (AutoZone)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
