Got the ForScan and OBDLink MX today. Trouble connecting
At first, I only have FORScan in my iPhone 6. Plug in the OBDLink MX+ with key on engine off. Turn on blue tooth on iPhone. Connect to the OBDLink MX+ after pushing that little button in the front, then it shows connection is made. Open the ForScan app. Hit connect no connection. Says no ELM found.
Fwiw Forscan advises against the OBLink BT for iOS,
https://forscan.org/forum/viewtopic.php?f=4&t=6142
the only one they say works is OHP wifi
According to the FORScan website...
"This version of manual is actual for FORScan Lite for iOS version 1.4.* .
Current version of the application supports only WiFi ELM327-compatible adapters and also Kiwi 3 Bluetooth Low Energy (BLE) adapter. "
With the popularity of the OBDLink devices, I imagine forscan will add compatibility for them given time...it seems like they make regular revisions to their applications...perhaps an email to the developer to inquire about when they will be adding support for the OBDLink MX+ in the iOS app will yield you a timetable...
Why are you guys opposed to buying the exact unit Forscan says works ?
this is the only unit Forscan recommends for iOS use.
i realize at $30 it is a few bucks more then the generic eBay ones but it’s still hundreds of dollars less then AE program.
fwiw,
the full Forscan program on a Windows 7 computer is far more useful better then the Mobil app and you can get a very suitable computer on eBay for $60.
A refurbished rubberized case Dell Lattitude 2110 with Windows 7 pro is $59 and makes a perfect Forscan setup.
https://www.ebay.com/itm/Dell-Latitude-2110-10-1-Intel-Atom-N470-1-83GHz-2GB-160GB-Windows-7/202398590646?hash=item2f1fe566b6:g:WnUAAOSwQc5bbgF Z
Paired with a $30 obdlinksx USB it is far more useful then the mobile versions.
fwiw,
Received 3,102 Likes
on
https://www.amazon.com/OHP-Diagnosti.../dp/B06XJL31Z7
fwiw,
https://www.amazon.com/ScanTool-OBDL.../dp/B005ZWM0R4
fwiw,
used the one linked above and forscan works perfectly every time.
on
fwiw,
fwiw,
Your FWIW will not work with the OHP - according to the chart above. It seems one must go iOS, or anything else - or have two adapters. I would opt to looking into finding out if they can get FORScan to play nice with the MX+, then you would have the quality and features of the OBDLink, along with the cross-platform versatility.
FTE used to preach AE, but things change. The FORScan forum will likely flip the record and try a new tune when options become available.
