Repairing My Stolen Truck - Ford Truck Enthusiasts Forums
Old 12-13-2018, 12:38 PM
Gotanoldtruck
Gotanoldtruck is offline
Gotanoldtruck is starting off with a positive reputation.
My 1997 F250 was stolen about a month ago. I just recovered it. They broke out the passenger side door lock to get in, busted the key ignition cylinder, jimmied off the VIN plate from the dash. No other damage that I have discovered yet. Without overdoing it (the truck is my daily driver with 310,000 miles) what advice do you have about either a hidden kill switch or keyless start? And how to restore my door sheet metal where the cylinder was jimmied out. I am thinking about deleting that key hole.
By the way, I looked at buying an identical replacement truck. This truck is worth 2X what I paid for it 10 years ago. Not sure why.
Thanks in advance for your input.
4x4 Turbo Diesel
Old 12-13-2018, 03:01 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
An ON/OFF connected directly to the starter solenoid signal wire with the switch and wiring hiden where only you know where ots at.
Glad you got your rig back, there is a guy in the Superduty section that also got his stolen yesterday.
Old 12-13-2018, 04:02 PM
Hit Man X's Avatar
Hit Man X
Hit Man X is online now
Hit Man X is gaining momentum as a positive member of FTE.
Thumbs up
You may want to consider LoJack for it too, it is not that expensive.
Old 12-13-2018, 04:40 PM
fordpride's Avatar
fordpride
fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Glad you got it back. First get with state police to get the VIN tag taken care of. Is insurance not covering the damages ? For the cylinder lock it would help if you could post a picture of the damage. To disable it you can wire a switch to the starter solenoid or to the CPS signal wire.
Old 12-13-2018, 04:45 PM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
Maybe use the Club?
Old 12-13-2018, 05:10 PM
fordpride's Avatar
fordpride
Originally Posted by BBslider001 View Post
Maybe use the Club?
you have to catch in the act to be able to use a club. Lol
Old 12-13-2018, 05:29 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
LOL!
Old 12-13-2018, 10:47 PM
BBslider001
Old 12-13-2018, 11:08 PM
Bob_T
Bob_T is offline
Bob_T is gaining momentum as a positive member of FTE.
PHP Hydra chips have No Start position that a thief is very unlikely to figure out. Probably other chips have a similar anti theft position.
I also have a toggle switch on my electric fuel pump.
Old 12-14-2018, 12:17 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Bob, is the no start position #17? To be honest I've never played with it. The trouble with cutting the fuel pump is they can still start it and take off and just running it hard it will suck fuel and run. Hard on the injectors but its happened to me a couple times on the road and the only thing I noticed was a lot more noise. The starter defeat sounds better.
Old 12-14-2018, 12:34 AM
AK gman's Avatar
AK gman
AK gman is offline
AK gman is starting off with a positive reputation.
I have a TS Performance chip i got several years ago that has a no start position. It will turn over and glow plug light comes on . A thief would think it just wont start. I use it all the time. If you plug the key hole they will just break glass. We have such weak laws for car theft in Ak that vehicle theft is out of control in Anc. In some cases when caught in stolen vehicles they dont arrest them or take them in, just give them a court appearance. Need to catch them and get them out of the gene pool.
Old 12-14-2018, 05:20 AM
Bob_T
Bob_T is offline
Glenn, yes, I think the no-start is number 17 or the last position. Iíve never messed with it either. PHP told me itís more or less permanently programmed in and we canít over write it with another program.
Old 12-14-2018, 08:12 AM
BuddyBarnes
BuddyBarnes is offline
BuddyBarnes is starting off with a positive reputation.
I did not know this. I have always thought -no fuel pressure , no start. Thanks
Old 12-14-2018, 11:35 AM
Airstreamer67
Airstreamer67 is offline
Airstreamer67 is starting off with a positive reputation.
I've got an automatic transmission and therefore don't need the no-start-without-clutch-down protection. So, I found those no-start clutch switch wires just above where the clutch is normally located , cut them, and wired them to a hidden switch. When the switch is open, the engine won't turn over just as it wouldn't with the clutch up on a standard transmission.
Of course, the engine can be made to turn over by shorting the solenoid under the hood or perhaps even at the starter, but many times any complication will deter a thief.
Old 12-14-2018, 11:44 AM
oldbird1965
Interesting, I didn't know those wires were there on a auto truck.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
