351w EFI timing cover with a standard rotation water pump?
Hello everyone!
I'm nearing the end of my big windsor build, and it's time to get the tinwork and get the engine buttoned up. the block is a F4TE roller block, but the engine itself is going onto my 68 Torino. As such, I need a standard rotation water pump.
Since I have no need for a mechanical fuel pump boss, can i get a timing cover for a 94 F150, and use it with the standard water pump, or do i need to source a timing cover that matches the pump?
Thanks for your help in advance!
No, that F150 cover only works with the reverse rotation pumps they came with. The late 80's Crown Vic/Towncar/Marquis used a std rotation cover and pump. I'm running this on my 331 with the late 88-up Crown Vic pump which is aluminum, the earlier versions had a cast iron pump. Or you can use any 1970-up timing cover from anything but the early Broncos. Ford revised the F series and Mustang pumps in 1986 to that reversed setup cover and matching pump
68 or 69 Torino? I'm guessing you wrote 69 because that was the first year for the 351.
There were some changes around those years with pulleys and dampers, and even possibly where the timing pointer on the cover was. I would think the complete "front dress" parts from a 1968 Torino 302 would be the best match, they should all fit the 351 (other than the belts).
Will you be using single groove pulleys or double?
The timing pointer location will need to match the timing marks on the harmonic balancer you're using. I'm thinking the cover will have the pass side inlet (water pump) pointer,(cast into the cover) so you'll need the stamped bolt on pointer used on later engines for a 351W..If you use a driver's side inlet pump, that will hide the pass side pointer on that cover. The nice thing about the later covers (1980's) is they used locating dowels to positively center the front seal. With the earlier covers you needed to use a tool to center the seal before tightening the cover bolts.
What cover are you talking about ? The Windsor he's got has the cover with the reversed ports, it only works with the pumps it came with. The earlier Mustang reverse pumps fit the earlier std rotation cover. Then there's the Explorer/Mountaineer and the 94-95 Stang pumps that use a completely different timing cover that only fits these pumps.
And yo50 year old ? These were produced up until 1991 for the Crown Vic's. I have three hangin in my shop if anyone wants one. $25 a pop plus the ride. And my point was the OP's timing cover does not work with a std rotation pump, which is what he was aiming to use with just a water pump and alternator to drive.
81ChopTop
02-25-2016 07:41 PM
53OlderThanMe
09-16-2008 10:02 PM
Squeak51
02-19-2005 12:15 AM
dazed12769
07-15-2002 12:16 PM
