How much front lift to perfectly level a 2004 SD? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-12-2018, 08:23 PM
RenoHuskerDu's Avatar
RenoHuskerDu
RenoHuskerDu is offline
RenoHuskerDu is gaining momentum as a positive member of FTE.
My 04 F-350 sits perfectly level. I have to air up the bags if I put much load in there at all, otherwise it's lower in the back.
But I didn't do the leveling kit, it came that way when I bought it. Now I want to install new front shocks, and I'm not sure how much lift it has in the front.
So if an 04 leaf sprung F-350 4x4 sits perfectly level unloaded, how much was the front lifted?
RockAuto has these KYBs https://www.rockauto.com/en/moreinfo...427891&jsn=604 for a 1 - 3 inch lift. $50 plus armNaLeg shipping.
JC Whitney has these Daystar Scorpions (27% rated them only 1 star, says made in USA in ad but Mexico is stamped on the shocks) https://www.jcwhitney.com/details/Fo....html#plpslot2 for a 2 inch lift. $40. JC Whitney also has Skyjackers and ProComp that fit lifted trucks for a few dollars more, Clint.
Old 12-12-2018, 08:28 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Show us some pictures of the front suspension
Old 12-12-2018, 09:17 PM
RenoHuskerDu
OK, but it'll be morning. Dark out there now, coyotes howlin.
Old 12-12-2018, 11:58 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Amazon has the KYB $57 prime. I run the KYB on my Dually, would definitely buy them again.
KYB 565081 MonoMax Gas Shock
Amazon Amazon
Old 12-13-2018, 09:21 AM
RenoHuskerDu
KYB 565081 MonoMax Gas Shock https://www.amazon.com/dp/B000C44CVM..._QzEeCb35BPJ6Z
Yeah I spotted that last night and put two in my basket. When you factor in RockAuto's ArmNaLeg shipping cost and bot-only customer service, Amazon is cheaper. Those Daystar Scorpions are apparently junk. I've run ProComp before and they were decent shocks. I think I will go for those KYBs as soon as I post some pics here and get a little more feedback. I just have to get my butt out there in the morning cold and crawl under the truck...
Old 12-13-2018, 10:19 AM
RenoHuskerDu
Here are some pics. Notice that the front suspension bump stops have not contacted the pads at all in months, maybe never, even though we live miles down a rough dirt road. I have about 4" from the pad to the rubber bump stops.
I'm going to estimate that it was a 2" front lift.
If you wonder why it's not completely level here, it's because I have 22 psi in the rear airbags.
Left front suspension
Right front suspension, showing no contact.
Old 12-13-2018, 09:06 PM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.DieselBeast01 is gaining momentum as a positive member of FTE.
It appears to have a mini spring pack leveling kit on it. I had one of those on my '01 super duty. Mine was 2", but I think they came in 2.5" as well. The bottom 3 short leafs make up the kit. If I remember correctly, the stock leaf spring only has 3 leafs. So the bottom ones are the add on pack.
Old 12-13-2018, 09:27 PM
RenoHuskerDu
That makes sense. Here's something similar on fleabay https://www.ebay.com/itm/2-2-LEAF-PA...E/283183789615 Three extra short leaves under the pack would have no effect on the bump stop clearance. But it would slightly stiffen the ride. My bump stops never touch. It all makes sense.
Thanks for the info.
Old 12-13-2018, 09:38 PM
DieselBeast01
Yep that is exactly like the one that I had on my old 2001. Back then, it was actually the best way to level unless you forked out the cash for actual 2" lift leaf springs. I had a shackle leveling kit on that truck prior to doing the spring pack, and it was horrible. Truck rode awful, and and suspension geometry was slightly off due to shackle kit on lowering the rear of the leave spring.
Old 12-13-2018, 09:47 PM
Colorado350
‘Well, now you have a choice to make; leave it like it is or return it to stock...
Old 12-13-2018, 09:52 PM
DieselBeast01
I would leave it, wouldn't be worth the hassle to remove it. Just buy 2 inch longer shocks. Go with bilstien shocks if you want the best.
Old 12-13-2018, 11:24 PM
Colorado350
I’m not sure about the best shock, maybe the best marketing campaign…
Old 12-14-2018, 10:22 AM
RenoHuskerDu
Oh, I'm leaving in the lift, for sure! The ride isn't very harsh at all. But if you look at my sig, you'll see that we mostly drive 3/4 ton or 1 ton Fords, so we may be a little bit warped, as it were....
I do love Bilsteins, but they would have cost nearly 3x as much as the KYBs I ordered. Back in the day, KYBs rode like crap, but I hear on this forum and from friends that they have improved.
Old 12-14-2018, 10:23 AM
RenoHuskerDu
People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.
Amen, and God bless the sheepdogs
Old 12-14-2018, 04:15 PM
DieselBeast01
I've bought cheap shocks before, and they were just that, cheap. In my opinion, and there may be some that disagree, you get what you pay for when it comes to suspension components.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
