Block to Trans Spacer question - Ford Truck Enthusiasts Forums
Old 12-12-2018, 10:53 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
I'm going from a c6 auto trans to a zf5. Can I use the same spacer between the block and the trans??
Old 12-12-2018, 12:04 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
F-250 WARHORSE has a good reputation on FTE.F-250 WARHORSE has a good reputation on FTE.
I doubt it; you need that zf5 one I bet I have I will check difference for you and follow up. I bet starter will not work properly
Old 12-12-2018, 12:29 PM
F-250 restorer
Thanks, that is appreciated. I'm running a 77 engine now, with a efi starter for an auto. I had to add a washer between the starter and mount to get it to disengage and not engage when I punched the gas. I will check the opening before I put the trans in, but if it is only thickness that is a concern, then I will go ahead with the install of the zf. Oops, I just thought about the pilot shaft. Well, I'm going to find out how it works. Everything is scheduled and has to go today. Hope it works. It is another of the small details that no one mentions when doing this swap. Dagnabit.
Old 12-13-2018, 01:17 AM
Rollingscrapmetal
Rollingscrapmetal is offline
Rollingscrapmetal is starting off with a positive reputation.
Count the teeth on the fly wheel/flex plate I believe with most autos you have the smaller one and need to switch but the c6 and zf5 are the bigger pattern
Old 12-13-2018, 10:28 AM
F-250 restorer
If I need a larger opening to allow for the flywheel, then I'll modify the plate. I was concerned about the thickness of the spacer plate and it would affect the pilot shaft depth into the bearing, and also how deep the starter teeth engage the flywheel. I don't believe the older spacer is thicker than the newer one specific to the zf. If there is a thickness diff., it is minimal. Hopefully it won't hurt the p.shaft bearing, and I will be able to add a spacer between the starter and trans to keep the starter from engaging too deeply.
When you mate a 77 engine with a 91 trans, there are many measurements, etc., that no one knows, and this, the thickness of one spacer as opposed to the other, and how it affects the p.shaft/bearing interaction, is one of them. Thanks for the help.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
