ProComp 22415 - add anti-wrap leaf? - Ford Truck Enthusiasts Forums
Old 12-11-2018, 11:50 AM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Looking forward to installing the new rear springs, I'll be removing the factory block and installing the 22415s. Looking for thoughts on adding the OEM anti-wrap leaf to the ProComp pack... bad idea? Waste of time? Or will the higher-arched spring be more susceptable to wrap and benefit from the OEM leaf and snubbber?
Old 12-11-2018, 01:23 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
How much do you use 4 low and heavy throttle ?
do you tow and leave from a dead stop at full throttle ?
If that isn’t your use then leaving it off is no biggie.
Old 12-11-2018, 01:58 PM
PrescottIce
I was hoping you'd answer up!
4 low, more than occasionally but not under heavy throttle - more picking my way through rocks or deep ruts/washouts on inclines.
I don't tow much at all, and when I do, it isn't heavy loads and no wheelie attempts on launch.
I guess I have my answer - but I'll leave some room on the u-bolts in case I change my mind and need to make a showing at the Trailer Towing 1/8th mile Nationals.
Old 12-11-2018, 02:38 PM
rickelrod
rickelrod is offline
rickelrod is starting off with a positive reputation.
So happens Im in the midst of rear pro Comp spring R & R now and was wandering the same. Its been a breeze except for the lower, rear shackle bolt. What a PITA!
Old 12-11-2018, 02:56 PM
PrescottIce
I'll be curious to hear what you wind up with for u-bolts - I anticipate starting installation about this time next month, gotta get past Christmas presents for others before I spend more money on gifts for the Ex... a trackbar and brake hoses. Her side of the tree already has springs and shocks, wheels, a front parking camera, new belt and idler pulley...
Old 12-11-2018, 03:34 PM
rickelrod
Mike, I bought these.
Pro Comp 50191 Rear U-Bolt Kit Ford F250/F350 '99-'08 Pro Comp 50191 Rear U-Bolt Kit Ford F250/F350 '99-'08
I will confirm as to whether or not they are correct once installed
Rick
Old 12-11-2018, 03:36 PM
pirate4x4_camo
If you are not using the block with a taper in it make sure to leave room for a wedge to correct drive line angle.
They get bolted in with the springs center pin ( you may need a longer pin)
use 2 C clamps to hold the spring together when unbolting the pin and installing the wedge.
fwiw the 2* seems to be the one most commonly needed.
3 Inch Axle Shims | Axle Shims | WFOConcepts.com
Old 12-11-2018, 03:41 PM
PrescottIce
Great advice and data, thanks. More stuff to buy!!! WhooHoo!!!
Old 12-11-2018, 03:48 PM
rickelrod
Pirate, If I am not planning on installing the slapper will the center pin be long enough?
Old 12-11-2018, 04:03 PM
pirate4x4_camo
depends on what center bolt they used, sometimes it is long enough sometimes there are no threads left and you need a longer one.
Old 12-11-2018, 04:04 PM
rickelrod
understood. Thank you!
Old 12-11-2018, 04:05 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
i just ordered the right procomp leaves to eliminate theneed for a block.u should do the same if you can.
Old 12-11-2018, 04:10 PM
rickelrod
I ordered the 22415 and 22210 Pro Comps with the Bilstein 33185552 and 33185569 5125's. If I understood correctly I can eliminate the block and expect about 3 inches of lift which will clear my new wheels and 35's
Old 12-11-2018, 04:12 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i think thats the combo im running also with no liftblock, search back in the posts on this site i listed what i installed with picks on the height thread i believe.
pirate4x4_camo
Mike, I bought these. Pro Comp 50191 Rear U-Bolt Kit Ford F250/F350 '99-'08
Rick
be nice if they specified the length on those.
I like to use new plates
3" Leaf Spring Plate, Pair | Leaf Spring Plates | WFOConcepts.com
With no block you want 8 long 5/8 ubolts for a 3.5 diameter axle
WFO Individual U-Bolt Kits | U-Bolts | WFOConcepts.com
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
