is there a way to get cruise control to stay on - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-10-2018, 06:48 PM
emanaresi
emanaresi is offline
emanaresi is starting off with a positive reputation.
Only on Fords that I have owned does the cruise control default to off when you turn the car off and back on.
Am I doing something wrong?
I want the cruise control main to stay on so I don't have to press the on button before being able to set the cruise speed.
I know this probably seems like it is no big deal... And it's not, but it would be nice.
Old 12-10-2018, 06:53 PM
seville009
seville009 is online now
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
That’s what it’s supposed to do; turn off when the truck is off
Old 12-10-2018, 06:56 PM
emanaresi
I understand that is what Ford has decided it should do, but our VW, Honda and the Mazda we used to have, if you turned it on it would still be on when you turned the car back on.
Old 12-10-2018, 06:59 PM
GABAR's Avatar
GABAR
GABAR is offline
GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.
Nope......Once the vehicle is turned off, cruise control is turned off. Also, regardless if it would stay on like some vehicles, one still has to hit the button to activate it or when the intended speed is reached so you`re really only talking about hitting one button or two.
Old 12-10-2018, 07:00 PM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
First, I can’t think of a single vehicle I’ve owned that could default to “on” like you describe. Seems like a real potential safety issue to me.
I am not aware of any method to accomplish what you want. Though it occurs to me that you could disassemble the switch and hard wire it.
GABAR's Avatar
GABAR
GABAR is offline
LOL...............True.
Old 12-10-2018, 07:01 PM
ShotgunZ71
ShotgunZ71 is offline
ShotgunZ71 is starting off with a positive reputation.
Minor annoyance, but I've gotten used to it as well. Guess the whiners with the start-stop engines need to get used to turning that off each time as well, rather than drown each other in tears on online forums! No big deal, just press a button. After all, they did START the damn thing to being the trip.
Old 12-10-2018, 07:04 PM
GABAR's Avatar
GABAR
GABAR is offline
lol.............so very true. Just reach up and hit the button.
emanaresi
eh...like I said, really not a big deal, maybe it is a domestic vs import thing, who knows.
The VW actually has a toggle switch on the stalk that turns the cruise main on and off. So it does not reset when the car is turned off.
The Honda and Mazda, it just stays on...
My old F150 was just like the new 350, I just find it a little annoying. I go to set the cruise out of habit and nothing happens because I forgot to turn it on.
Just something to get used to, not a big deal. Thanks for the help.
Old 12-10-2018, 07:18 PM
VA13FX4's Avatar
VA13FX4
VA13FX4 is offline
VA13FX4 is gaining momentum as a positive member of FTE.
All of my prior vehicles it would be on when I started the vehicle. Mostly GMs and Hondas. Never a "safety concern" with any of those vehicles. IDK if it is possible to modify the power to that switch via FORSCAN or not. I asked the same question about the engine brake and never got a real answer. Mostly just got the response saying "it's just a simple push of a button" or it's just a minor annoyance." I use the engine brake 90% of the time I go anywhere and the cruise probably 60% of the time, so it would be nice to have them just stay on, which is why the question was asked. The real "minor annoyance" here is people only sharing opinions about why they feel there's no need to figure this out and not sharing anything meaningful about the ability to accomplish it.
Old 12-10-2018, 07:23 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
I think a majority of the responses on the exhaust brake were that they would like it to retain the setting, or at the very least, come on when the truck sees that there is a trailer connected.
I don't have any of my vehicles that retain the cruise control setting. Would it be nice? Yeah, but I'm not that enthusiastic about that feature.
Old 12-10-2018, 07:30 PM
STIBUILDER's Avatar
STIBUILDER
STIBUILDER is offline
STIBUILDER is starting off with a positive reputation.
Plus 1 on the Exhaust Brake, my 2007 Kodiak just has a switch. But its exhaust brake is insanely good.
Old 12-10-2018, 07:36 PM
Ben Elliott
Ben Elliott is offline
Ben Elliott is starting off with a positive reputation.
My 16 3500hd Chevy would “stay on” after you started back up meaning the light would be on but you would have to hit the “set” button to engage it again. Basically it saved you one push of a button on the steering wheel.
Old 12-10-2018, 07:46 PM
slapshot12
slapshot12 is offline
slapshot12 is starting off with a positive reputation.
I have a '15 Chevy Tahoe PPV for work and the cruise does stay on each time I start the truck, but still have to set the speed each time. I like having it already on so I can just set the speed I want. Neither of my Super Duties have stayed on, and I don't recall any of the Ford's I've owned that did.
Old 12-10-2018, 07:51 PM
Msu50000
Msu50000 is offline
Msu50000 is starting off with a positive reputation.
Agree. Escalade is ready to be "set", it eliminates push of one button, simple thing but every single time we take a trip and I get back into the Ford it is something I notice and would appreciate.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
