E250 Heater Core Fittings - How to remove?
on
1 Post
can you describe the lines that you have..????
if they are the spring loaded clamp that is a one time use clamp and you can cut it off and replace it with a hose clamp.. if you have the form fiited hose that are an intregal part of the core then they should pull back thur the hosing the the core is secured to.
i have a F 150 and my hoses are on at the entry point for the core with the one time clamps and when i come time to replace the core i will be removing that style and replacing with hose clamps..
hoped this info helped if not please add more information...
f150rd
12-19-2011 07:55 AM
418
12-02-2010 06:50 PM
