View Poll Results: How often is your truck in the rain/snow or getting washed?
Never. I never wash my truck and it does not rain/snow where I live
0%
Voters: 99. You may not vote on this poll
2017 2018 2019 Door Locks Freezing
VA13FX4, so, you are reporting something new ( to me, anyway) I do not recall others reporting that repeated closings finally latched, I assume that yours would stay latched fir the followimg driving, did the next cycling of the door latch secure properly?...I recall back with Ford’s ‘Magic Three-Way Tailgate slamming the gate only to have a ‘closed’ latch bounce the tailgate back to you...the fix was to take a large screwdriver and move the pawl to the ‘open’ position, then slam the tailgate and all was goid.
I don’t know if today’s latches share any of those old design details...
That is intetesting, what year is yours?
( a general question to all, is this occurring to all trim levels, XL to Limited?)
If you’re onto something regarding opening from the inside, perhaps you can roll down the window and see if opening from outside solves that.
It is good to hear (relatively speaking) that you are able to close it after 2-4 attempts...keep us posted, you may help resolve this!
The video is helpful to me who has not witnessed this issue...everybody seems to claim that when it acts up it will not latch at all while you are getting much better results ...Q: when it does not latch, does locking it change the outcome?
Q2: are all of the door handles the same ( except for chrome, paint or black plastic?
maybe it is the cable routing...maybe it chafes and hangs-up, maybe some are worse than others, maybe some 'last longer' but then one would think that if this were to be the case, Ford would open a few door panels and determine the real fix... (I cannot factor temperature into this thought chain)...
I have an early 2017 and noticed two things this year when got below freezing:
- Passenger door would not unlock with remote, had to use inside handle
- Noticed a white bead (sealant?) push out around outside of trim on outside driver door handle. It pushed out 3/4 inch into loop, when I pulled it it broke apart?
Now with this new round of problems with my latches I can manually lock the door and get it to remain closed. But the lock is super stiff almost to the point that I may break my key as I'm trying to lock the door.
#28
#29
#30
Just made a video. Spoiler alert... inside door handle is my issue...
https://youtu.be/BRWnVsk5D5E
