1964 F100 4pd floor hump foam surround - Ford Truck Enthusiasts Forums
Old 12-09-2018, 11:16 PM
olfclvr
olfclvr is offline
olfclvr is starting off with a positive reputation.
I'm rebuilding my 292 motor and have the transmission out. There was some sort of "foam" surround where the shifter comes up through the floor. It's about 4 or 5 inches in diameter. Does anyone know if there is a replacement or what you recommend? Also, the clips that attach to the cab body to bolt the hump down have broken. Are there replacements for those or are washers and nuts the answer?
Thanks!
Old 12-10-2018, 02:42 AM
Christmas's Avatar
Christmas
Christmas is offline
Christmas is starting off with a positive reputation.
Foam replacement for the shift tower is not available that I know of. I used an old memory foam mattress topper. They sell those clips everywhere even the hardware store just get the screws to match.
Old 12-10-2018, 11:39 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
TA455HO has a good reputation on FTE.TA455HO has a good reputation on FTE.TA455HO has a good reputation on FTE.
The cage nuts are 5/16" - 24. One possible source for them at the following link.
Bulk3
Or if you find some similar in a 5/16" - 18 then just get 5/16" - 18 screws as Christmas mentions.
Chad
Old 12-10-2018, 11:55 AM
olfclvr
olfclvr is offline
Wow thank you so much, this forum is great and you guys are awesome!
Old 12-10-2018, 12:02 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
Here's a picture from a page of the AMK Guide to Ford Fasteners. There were 4 part numbers that are the 5/16 - 24 and 3 part numbers for the 5/16" - 18 so you can possibly use those to help guide your search. Originally it would have been the 359218-S2 - the trailing 2 meaning black phosphate coating - on our trucks, but it makes little difference.
Chad
Old 12-10-2018, 01:23 PM
6t6merc
6t6merc is offline
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
I think I used J-nuts there, Chad, similar to or the same as the ones used on the front sheetmetal. Mine's a '66 though.
Eric
Old 12-10-2018, 02:09 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
Eric, you can use whatever you like. I was referring to what I've found to be stock on many trucks and what the MPC calls for. The nice thing about the stock pieces is they don't create any gap between the plate and the floor.
Enjoy!
Chad
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
