1972 F700 Decode and Brakes - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Reload this Page >
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 12-04-2018, 09:08 AM
willisgiles
willisgiles is offline
willisgiles is starting off with a positive reputation.
Just got a F700 from a '76 Rider Moving Truck that im looking to get a VIN decode on from you good Sir Dummy! Last time you really helped me out a lot and i appreciate it.
VIN: F70FVN26812
Mainly im hoping this 5 speed might could replace the 4 speed New Process 435 i got in the ol skoolie.
Old 12-07-2018, 12:26 PM
willisgiles
I hope I didnt post this in the wrong place?! Sorry if so!
Old 12-07-2018, 01:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
VIN: F70FVN26812
F70 = F700 (gas).
F = 391 4V
V = Kentucky Truck Assembly Plant.
N26812 = 1972 // 1972 serial number range: M40,001-Q00,000 // 1976 serial number range: A10,001-D25,000.
TRANS code stamped separately on the 2nd line of the Warranty Plate, riveted to the left door face below the latch.
You didn't post this in the wrong place, I took 3 days off.
Old 12-09-2018, 08:11 PM
willisgiles
What that plastic connector called on that brake system? Trying to order some online
Old 12-09-2018, 10:02 PM
85e150six4mtod
85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Posts consolidated.
"Plastic connector...." Ok, brake related, but where? Can you post a picture? Is in in the cab, on the firewall, on the booster, at the wheel? The more info the better, and pictures are worth more than 1000 words here.
Old 12-10-2018, 12:02 AM
willisgiles
Here is a picture of the photo i was commenting on from a different post.
Old 12-10-2018, 12:04 AM
85e150six4mtod
No picture.
Old 12-10-2018, 12:06 AM
willisgiles
Yeh getting super frustrated with this site ive tried 10 ties in the last 5 minutes to upload the photo
Old 12-10-2018, 12:08 AM
willisgiles
Old 12-10-2018, 12:09 AM
willisgiles
Ok 10th time im writing this. Jesus. Ok so the plastic piece connects the vacuum line off the engine to the vacuum gauge on the dash to the vacuum booster underneath the truck. Trying to ginf out what its called and where i can find online not a junkyard.
Old 12-10-2018, 12:15 AM
85e150six4mtod
The white blob with 3 hoses, right? Is that small hose just hanging there? Where is the master cylinder? Is your clutch linkage or hydraulic?
That blob appears to be a check valve out of a firewall mounted master cylinder power booster. That is, if one of those two larger lines is connected to the intake manifold. The other appears headed under the truck, perhaps to a frame mounted brake booster, similar to one of these?
https://www.vanderhaags.com/Search-R...=brake-booster
Old 12-10-2018, 12:17 AM
85e150six4mtod
AFAIK, you have a really goofed up system there. No way that piece should be where it is, doing what it's doing. Clearly you can see this isn't factory, and there is no need to replace that part. That part will be eliminated when you restore a factory-like brake system. The way things look, you don't have brakes right now....???
Maybe Numberdummy can post a parts book view of the braking system. Stand by for that.
Regarding pictures, lots of complaints on that, can't do much but hey, you got it so congrats on that!
Old 12-10-2018, 12:32 AM
85e150six4mtod
OK you got this picture from another thread, right?
https://www.ford-trucks.com/forums/1...ck-brakes.html
Whatever was going on there we will never know, and doesn't or shouldn't apply to your truck. We need a picture of your truck.
Old 12-10-2018, 10:26 AM
willisgiles
So i posted that picture because its the exact part im looming for and its coming off of a STOCK vacuum brake system. Nothing out of the ordinary there. My 1969 Ford B600 School Bus was set up the same way and so is this 76' Ford F700. It may be a check valve i google vacuum booster check valve and found a picture of the part but i know they make them to connect two hoses as well as three hoses (which is what is in the original picture i shared and what i am looking for.
Old 12-10-2018, 10:54 AM
willisgiles
I found the perfect white blob match thanks to the help of whomever said it was a check valve haha thanks! Damn thing is expensive!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
