'99 F-250 locker options - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-09-2018, 08:19 PM
kcducttaper
kcducttaper is offline
kcducttaper is starting off with a positive reputation.
I live on a decent hill and am potentially interested in dropping a locker in my 2wd '99 F-250. It currently has 3.73's in the rear, but I wouldn't be opposed to going to a 4.10 or so because I've got the 5.4 under the hood. I'm thinking the cheapest way to go would be to steal a whole axle assembly from another SD that had an FX4 package or something. I would really like an e-locker that I can engage with a switch on the dash. Are there any SD's with an axle like that that would be an easy swap?
Old 12-09-2018, 08:32 PM
99f350sd
99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
A few guys have Detroits and love them. Me included.
Old 12-09-2018, 08:37 PM
eddienelson's Avatar
eddienelson
eddienelson is offline
eddienelson is starting off with a positive reputation.
Im leaning on the Eaton truetrac. Google it. Its a really impressive unit. Especially if your doing a lot of in town driving.
Old 12-09-2018, 08:58 PM
99f350sd
99f350sd is offline
Yup they work.. If you get a tire off the ground you'll have to play with the brakes. I don't have time for that foolishness.
I plow 20 customers. I can't tell it's back there. All I know is both wheels bite all the time. Just got a grizzly for the front to replace the lock right.
Old 12-09-2018, 09:45 PM
eddienelson
I didn't know about the brake thing. I thought both tires had constant forward power. Ill have to do some more reading on them. Thanks for the heads up. Why did you replace the lock rite?
Old 12-09-2018, 09:50 PM
99f350sd
99f350sd is offline
Too noisy and I might have broke a spring in it. The Grizzly is basically a Detroit so I got it... And at 1/2 price.. so no brainer.
Also I have a dana 50 up front and Detroit doesn't make one for that axle.
Old 12-09-2018, 11:53 PM
Pborgia
Pborgia is offline
Pborgia is starting off with a positive reputation.
True trac is great, never know its there. No more one wheel peel pulling into traffic on wet roads, dirt roads and snow are no problem. No switch to turn on, just works.
Old 12-10-2018, 08:24 AM
'01V10's Avatar
'01V10
'01V10 is offline
'01V10 is starting off with a positive reputation.
While the design of the truetrac requires there to be some traction to both wheels in order to transfer traction and therefor requires you to play with the brakes if one wheel is off the ground, how often are you hanging a tire in mid air in a super duty? Not saying there aren't people who do and maybe you're one of them IDK. Realistically though, a truetrac should be more than sufficient for most super duty owners and without the loading/popping etc that is often found with a true auto locker. If you are going to go through the expense of having either installed I'd recommend getting a gear change at the same time. You're already going to be paying for the labor and only have to regear the rear end. Might as well make the most of it. I don't know what size tires you're running, but I'd take a hard look at 4.30's. It sounds like a lot of gear, but it was a OEM option on a lot of trucks. I had them in my last V10 and have 3.73's in this one. It's a noticeable difference. I much preferred the 4.30's and they (and the truetrac) are on my list.
Old 12-10-2018, 09:35 AM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
I regeared to 4.10’s and installed a Truetrac in my 2wd Dually. The difference is night and day. The benefits of a Truetrac is that there’s no speed limits to which it will engage, no clutches to wear out either.
Old 12-10-2018, 12:46 PM
MD_7.three's Avatar
MD_7.three
MD_7.three is offline
MD_7.three is starting off with a positive reputation.
I'm also in the truetrac club...love it...there when you need it but no clanging/binding making turns...no clutches to wear out like in the factory setup
Old 12-10-2018, 02:49 PM
'65Ford
'65Ford is offline
'65Ford is gaining momentum as a positive member of FTE.
I have a truetrac in my crown vic. With one tire on slick mud, the opposite tire will leave a black strip on dry concrete when I tromp the gas. So I'm guessing you'd about need one tire completely off the ground or on wet ice in order for the opposite tire to do nothing.
Old 12-10-2018, 02:51 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.
ok...not to be cynical or anything but there has to be a downside somewhere in the tru-trac
Old 12-10-2018, 07:20 PM
carl2591's Avatar
carl2591
carl2591 is offline
carl2591 has a good reputation on FTE.carl2591 has a good reputation on FTE.
how much did that change RPM at 60 MPH.. do you find you are not having to push button to disengage OD for hills/ long pulls etc. ?? thinking of doing this as well.. 4.10 and TT
Originally Posted by Colorado350 View Post
I regeared to 4.10ís and installed a Truetrac in my 2wd Dually. The difference is night and day. The benefits of a Truetrac is that thereís no speed limits to which it will engage, no clutches to wear out either.
Old 12-10-2018, 09:31 PM
Colorado350
I havenít seen any, itís on when I need it and off when I donít. Thereís no chatter, noise nothing. I have a 2wd Dually so before the Truetrac Iíd get stuck on wet flat grass...seriously.
ĎI see about 200 rpm increase across the board more or less. Well, for hills Iím able to leave the overdrive on but for long mountain passes I take the OD off and rpms up to control EGTís. Keep in mind that Iím at 6500í and 99.9% of my travel goes to higher elevation 11,000í +. Iím dealing with thinner air which really robs power... If Iím DD, I can still drive 85 if I wanna without any where near redlining it.
Old 12-10-2018, 09:56 PM
eddienelson
Thats pretty impressive. Did you install the gears and true track yourself? How hard was it to do?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
