Heater core rebuildable? - Ford Truck Enthusiasts Forums
Old 12-09-2018, 09:57 AM
rwilly1
rwilly1 is offline
rwilly1 is starting off with a positive reputation.
I asked a radiator repair shop about fixing my leaky heater core and they said it would just be easier and cheaper to just replace it.
The stock core is much higher quality, the replacement I just installed sure does seem cheap.
What say you?
Repair or replace?
Old 12-09-2018, 01:49 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Replace. But with a quality one. Different brands build it different than others. Remember, you get what you pay for.
Old 12-09-2018, 03:14 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C7TZ-18476-A .. Heater Core / Obsolete
1967/72 F100/750 except 1968/72 F100/350 with factory installed integral A/C // 1973/79 F500/880.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
Old 12-09-2018, 04:08 PM
yardbird's Avatar
yardbird
yardbird is offline
yardbird is gaining momentum as a positive member of FTE.
I replaced the heater core in my '87 with an aluminum replacement instead of the higher priced brass OEM style available. I saved a few bucks, and the heat coming out of the vents is much hotter than with the stock core. But, there are so many fins so close together on the aluminum core the air flow is quite a bit less. I guess that's why the heat is hotter, but I would like more airflow, even though it gets so hot I have to turn the heat down pretty quick. I got mine at O'Reilly Auto Parts. If I had to do it again, I would get the brass OEM look alike.
Old 12-10-2018, 03:23 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
That's good to know, thanks for sharing!
Old 12-10-2018, 08:21 AM
rwilly1
rwilly1 is offline
Thanks for the replies.
im going to look around for higher quality than what I got.
I'm sure it will work, but I doubt it lasts long.
Thanks!
Old 12-10-2018, 01:57 PM
resonateur's Avatar
resonateur
resonateur is offline
resonateur is gaining momentum as a positive member of FTE.resonateur is gaining momentum as a positive member of FTE.
When heater cores and radiators leak, you have to remember that the entire assembly may be subject to the same failure in other areas. Repair rather than replacement is often temporary until the next solder joint, tank or tube fails....I learned that the hard way.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
