AUX switches on my first Super Duty
1-Drivers heated seat
2-Passenger heated seat
3-
4-Under carriage lights. I turn them on after I shut the truck off and the come on during remote start to light up the area as I approach the truck
5. Dash Camera.... I leave it on (always hot) when in public parking areas to record anyone hitting the truck while I'm gone
6-
3-
6-
The wires are terminated under the hood. Go online [or maybe even the owners manual?] to see which wire connect to which numbered switch. Connect your accessories power wire to it. Hook up a ground and enjoy your accessory! Its that simple! The relays are already in place.
the fuses and relays for the switches are also moved to the engine bay.
all this is right by the hood hinge on the drivers side.
there are other wires provided on the passenger side, if you need outside back INTO the cab.
https://www.ford-trucks.com/forums/showpost.php?p=17498619&postcount=32
whole topic here
https://www.ford-trucks.com/forums/1...l#post16638283
no.. the 17's and up terminate the wires in the engine bay only. with a lot more wire available..
https://www.youtube.com/watch?v=9CEY8LupfGw
https://www.ford-trucks.com/forums/s...9&postcount=32
whole topic here
whole topic here
probably actually makes it easier to wire stuff up with one continuous wire going out to the engine. I guess if you want to hook something up inside the cab, you can just cut the wire.
moving the relays out from behind the dash to someplace you can get to them is a nice change, plus the wires are a lot longer then they used to be..
the wires to the upfitters themselves don't care any good level of power. they just toggle the relay.. (I always used the ground leg to trigger relays, so no power ran on the wire at all)..
I don't think they document where those wires go in the cab...
but you have power in the passenger footwell fusebox.. the PTO wire is on while running... (its NOT a passthru wire)
https://www.viaircorp.com/oba/oba-constant
on the 12 i had it under the right side attached to the chassis..tank followed by the compressor
on the 18, with the power running boards, I am going to have to move the tank above the spare, like others have done.
just got the truck 10/24, so not quite done with mods.. (aux tank in tho).
