how do I remove rear headrest 2018 crew - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-07-2018, 09:46 AM
sdetweil's Avatar
sdetweil
sdetweil is online now
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
i want to remove the right rear headrest from my 2018 crewcab, so my rear facing grandson can see 'trucks' (his big thing)..
I was able to easily remove center (have to put it back now that I understand high bed camera zoom)
but altho I push the headrest post button, I can't get the hr to move.. am I just being not aggressive enough?
Old 12-07-2018, 09:49 AM
Poncho450's Avatar
Poncho450
Poncho450 is offline
Poncho450 is gaining momentum as a positive member of FTE.Poncho450 is gaining momentum as a positive member of FTE.
Haven't been out in my 2017 lately, but I seem to remember there being 2 buttons. Kind of a pain to hold them in while sliding the headrest up at the same time.
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Are you pressing both tabs in?
Old 12-07-2018, 09:52 AM
CPal
CPal is offline
CPal is starting off with a positive reputation.
Not sure why youd be having difficulty assuming its same as my 2017. Tab on outside right and inside left of headrest. Squeeze at same time while lifting up.
Old 12-07-2018, 01:07 PM
sdetweil's Avatar
sdetweil
It's the foldy headrest, push button on the side. Only one post clip on driver's side
Old 12-07-2018, 01:25 PM
ford390gashog
There should be two. Look at the other side, it is flush press both at the same time.
Old 12-07-2018, 01:43 PM
sdetweil's Avatar
sdetweil
the other post, left in this picture, does NOT have a release clip like the right side
Old 12-07-2018, 01:46 PM
PentaPop
PentaPop is offline
PentaPop is gaining momentum as a positive member of FTE.
The left one is hidden. Just push on the side of the plastic and it will move.
ford390gashog
I will take a picture at lunch but it does. It does not have a protrusion like the other side. It requires you to press inward.
Old 12-07-2018, 01:51 PM
CPal
CPal is offline
Old 12-07-2018, 01:54 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Alaskan_Warbird has a good reputation on FTE.Alaskan_Warbird has a good reputation on FTE.
What they said - it works. I took mine out too.
Old 12-07-2018, 02:13 PM
sdetweil's Avatar
sdetweil
Thanks guys. The little pic of the left side headest helped SOOO much.
Headrest out.
Why have two different retainers?
Ah well
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
