How many teeth flywheel for a 78 400? - Ford Truck Enthusiasts Forums
Old 12-07-2018, 05:08 AM
hail destroyer
hail destroyer is offline
hail destroyer is gaining momentum as a positive member of FTE.hail destroyer is gaining momentum as a positive member of FTE.
How many teeth flywheel do I need? 180t or 176? I'm swapping from a 351M to a 400 in a '78 f250 4x4 with NP435 4 speed. Thanks again!
Old 12-07-2018, 10:08 AM
ranger140892's Avatar
ranger140892
ranger140892 is offline
ranger140892 is starting off with a positive reputation.
I only know of 180 tooth 400 flywheel
Old 12-07-2018, 03:06 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
351M uses an 11" clutch, 400 uses a 12" clutch, but the 180T flywheel ring gear is the same for both.
D7TZ-6384-A .. Flywheel Ring Gear - 180 teeth / Obsolete
1977/79 F100/350 351M/400 // 1978/82 Bronco 351M/400 // 1980/82 F150/350 351M/400 /// 1983/97 F250/350 460.
Old 12-10-2018, 12:31 PM
dogdays
dogdays is offline
dogdays is starting off with a positive reputation.
Easier way to do it...
The 351M/400 flywheel is the same casting with different bolt holes. You do not need to buy a new flywheel. Here are your options:
1. Have a competent machine shop drill your existing flywheel for the 12" pressure plate. Mine cost $35.00
2. Use the 11" setup with no fear. If a 440 sixpack or an Olds 455HO or a Pontiac Super Duty 455 can use an 11" clutch, so can your 400.
This is the real answer. I used a 12" clutch because I had bought all the pieces at bargain prices and it cost less to redrill the flywheel than to buy a new 11" clutch kit.
R.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
