300 to 351W swap help
I have a 79 f250 4x4 with a 4 speed manual transmission (Np435). The original motor was a 300-6 but it is shot so I was gonna swap something in with more HP (V8). I think the only two choices I have are a 302 or 351W without changing the bellhousing?? Do I need to get different tower mounts and where can I find them?? What else do I need to do?? This is my first swap so all the help I can get is greatly appreciated!!
If it is anything like the 80-86 trucks then yes you need new different tower mounts.
Don't know from where? A parts truck? Did you check like LMC truck? Place a want add?
I am going to guess you will need to make changes to wiring for the sensors, coil, ALT., etc.
Then you have radiator, would need to be bigger and the inlets / out lets may be different between the 2 motors.
Then you have EXH hook up.
That is all I can think off the top of my head.
Dave ----
Dave ----
351W not available in F150/350 2WD/4WD & Bronco until 1981.
2WD: Same engine supports (aka towers/stands/perches): 1969/79 F100 302; 1975/79 F150 302; 1977/79 F100/350 351M/400.
daddy57
03-06-2009 08:53 PM
