FOLLOW-UP: Ford Reman E4ODs - Ford Truck Enthusiasts Forums
Old 12-07-2018, 12:46 AM
J.Amato
J.Amato is offline
J.Amato is starting off with a positive reputation.
Hey all,
I'm posting this as a follow up to my other thread asking for opinions on remanufactured E4ODs from Ford. The feeling was generally positive, so I wanted to make an actual post outlining the good and the bad as an alternative to local shops and online retailers.
If I run into initial problems, I'll post them here. If anything comes up down the road, I'll try to remember to post.
The reason I chose to go with a Ford reman is I am about to move roughly 300 miles from my current home, making a local shops warranty almost useless. I had debated the online retailers, but have doubts of them coming through, and the possibility of their warranty only reimbursing for labor. Not actually being billed in the first place.
The Ford warranty is a 3 years/unlimited mile parts and labor coast to coast at any Ford dealer.
I'm sure someone will chime in that "you can get 10x's the trans from a local shop or online at ____", and I'm sure you're right. But warranty coverage is a huge deal to many and it certainly influenced my choice.
So here it is, a brand spankin refurb from Ford. Complete with a new MLPS, torque converter, a pan full of oil, the warranty above and a fresh spray of silver paint!!
The total for this would normally run $2,342.52 plus any local taxes, but I caught a "sale" at $1,957.33 + $1,000 refundable core and 10% (yes, that's TEN PERCENT sales tax in Wa.) for a grand total of $2,253.06 after returning the core.
That price alone is pretty reasonable for even the most stock ford feeling rebuilt E4OD.
It's late so I will be getting to this install first thing in the morning.
Any questions people may have, please post. I would love to be able to target my posts.
Joe
Old 12-07-2018, 02:42 AM
timbersteel's Avatar
timbersteel
timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I look forward to your install. You got a great price on it.
Let us know how it goes.
Old 12-07-2018, 07:19 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
FORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputation
Why would you make a new thread for this though? People who search down the road and find your other thread will now only be getting the first half of your info.
Old 12-07-2018, 08:48 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Old 12-07-2018, 08:52 AM
J.Amato
J.Amato is offline
Originally Posted by rla2005 View Post
Beat me to it. Was working on getting a couple photos uploaded. Looks like you linked the other one as well. Thanks!!
About to get out on this balmy 26deg morning and knock this sucker out.
Old 12-07-2018, 08:53 AM
rla2005's Avatar
rla2005
rla2005 is offline
Could be worse...it's 8F in central Illinois this morning. Good luck!
Old 12-07-2018, 10:31 AM
J.Amato
J.Amato is offline
First SNAFU happened right on time. First thing.
Bolt securing the crossmember mount to the old trans rounded. Sourcing cuttoff wheel and new bolt.
Old 12-08-2018, 02:48 PM
J.Amato
J.Amato is offline
HOLY CRAP IS THAT THING HEAVY!!!
Got the trans up and everything buttoned up by about 5:30pm yesterday.
That sucker is a 2 man job even with a trans jack. I'm one sore dude today.
Changed out the VSS with an oreillys brand part. Was getting a 452 code along with the speedo not working.
Speed now works intermittently and I'm still getting harsh shift engagements at odd RPMs. Good news though is it's not stalling out.
I suspect the VSS from oreillys might not be of the highest quality.
Going to get a VSS from ford and slobber some dielectric grease on all electrical connections in that circuit and see if that solves it.
Old 12-08-2018, 07:50 PM
J.Amato
J.Amato is offline
New VSS from Ford changed nothing. Followed VSS wires from sensor, all the way up to terminal block in firewall. Greased the pins, no change. All wired are in good shape. Leaves me with a failing PSOM.
Ebay speedo will be here wednesday. I will be back from out of town saturday night. We shall see then. I'll report back.
Old 12-09-2018, 09:13 AM
FORDF250HDXLT
A new trans can't fix it's electrical operation issues.
Old 12-09-2018, 09:26 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
DE grease can't improve a connection, only prevent moisture intrusion & corrosion.
Too much can definitely impact connectivity. Don't slather.
The PSOM is probably the issue rather than speedo or VSS.
I'd have opened up the ECU for capacitor inspection/replacement before now too.
Old 12-09-2018, 11:20 AM
J.Amato
J.Amato is offline
Decided on the new trans after dropping the Pan 3 times and finding chunks each time.
Old 12-09-2018, 11:43 AM
J.Amato
J.Amato is offline
Good suggestion. Iíll pull it today and open it up
Old 12-09-2018, 11:26 PM
J.Amato
J.Amato is offline
Well I'll be d*mned.
Anyone know where I can find a write up on what components do what with this ECM?
I I think this blown capacitor might be the reason the PSOM is acting funky.
Old 12-10-2018, 09:10 AM
rla2005's Avatar
rla2005
rla2005 is offline
Zero interaction between that leaking capacitor and your PSOM issue. You have two separate problems.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
