FOLLOW-UP: Ford Reman E4ODs
Nothig noticably bad about the PSOM. It is getting power from the plug. But that’s about the extent of my knowledge in testing circuit boards.
Well, the problem appears to be elsewhere than the PSOM. The replacement lit up momentarily and I would swear I felt a smooth shift after first taking off. Then the speedo and odo went blank and it started hard shifting again.
I’ll get new capacitors for the ECM. Anything else I can check?
still getting a VSS code.
My first involvement with an OBS was 95-96 F250 powerstroke I drove for a carwash builder & service co .
The drums I frequently hauled would bust the high mount brake & bed light & fill with water when testing out the washes.
It'd kill the OD (on/off light flashing) & put it in limp regularly till I started carrying whatever fuse it was blowing after the 3rd trip to the dealer.
All my fuses are good. The only other electrical problems I have noticed are 1)the door switch has never worked to turn on the dome light. Dome light switch works. 2) when the speedo goes out, I noticed the head light switch gets shifty. The headlights will go off until I fiddle with the **** and even still, doesn't come on right. This is the first I have noticed this as this is the first time I have driven it at night. Not sure if there may be a connection between the headlights and the VSS circuit.
Headlights are a coincidence. The Positive lead was loose.
I'm really at a loss. I've traced the wires from the VSS in the differential all the way to the PSOM and I get 6.7 volts at those pins on the PSOM connector (this is with the truck running and stationary. I'm not sure what it would be if I jacked up the rear and read voltage then). The PSOM has good voltage with the ignition in the off and run positions. I have tested every single fuse on the truck with my meter and they all tone.
Does anyone know what the voltage reading should be going into the PSOM from the VSS? 6.7v seems low but if I'm thinking of the way the PSOM would read the VSS, it should max out the speedo at 12v. So maybe it's alright. This is the 2nd replacement VSS. This one is a Ford part.
What gets me is that if I leave the truck alone for a few days. Come back and start it. The odo lights up. then after a couple minutes, shuts off...
IDK what to do next besides limp it to the dealer and tell them to fix the darned thing.
VSS circuit diagram:
courtesy of Subford
A basic diagram
Attachment 279845
courtesy of Subford
Your DC measurement of 6.7 volts when the truck is stationary is odd, but I have never metered the circuit with the meter set to DC. Output voltage is 0 VAC with the truck stationary.
Some info on how to test the VSS output/PSOM input:
CHECK SPEED INPUT SIGNAL
NOTE: Only wiring harness end of connector is to be probed.
* Connect Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent to Pin 4 (speed in ) and Pin 5 (speed in -).
* Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
OR:
* If available, a frequency counter may be connected to Pin 4 (Speed in ) and Pin 5 (Speed in -).
* Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)?
Last place to ever take your truck. Most of them have no idea how the circuit works.
