Anyone have the Ebay 2" 2WD Level Kit? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 12-06-2018, 10:07 PM
L-ight
L-ight is offline
L-ight is starting off with a positive reputation.
I recently bought these https://www.ebay.com/itm/StreetRays-...97.m4902.l9144 and was going to install them tomorrow. I also replaced my shocks about 3 months ago with Bilstein 4600 in the front and rear as well. I did some searches and got mixed reviews on needing an adjustable caster bushing? Is the recommended or have some trucks been ok without it? Also would those front shocks bottom out quiet often? I do 99% pavement driving and 1% sand when going to beach.
Old 12-06-2018, 10:47 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is online now
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
Yes you will need to adjust your camber or your tires will wear quickly and it is going to handle poorly.
Dont know what length shocks you have but stock length ones would most likely top out before bottom out, either way it will ruin them if it does.
Old 12-06-2018, 11:27 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Been here. am there.
Need a full alignment. Well worth it tho. With the sag you have from years with stock length,,,,,, I'm rough on mine with a 9 ft western plow swinging away. Stock length with a 2 inch push lift. Highly recommend an alignment.
Denny
Old 12-07-2018, 08:40 AM
L-ight
L-ight is offline
Denny
I was already was going to get an alignment for sure. I am just going to also get the camber bushings to be safe. Also with my brand new bilstein 4600 shocks would I be ok with those or do I really need to get the shocks made for the 4" lift?
Old 12-07-2018, 09:13 AM
DieselDenny
I would install everything and take your shock off the mount and extend it with the tires on the ground. See how much length you have above or below the mount. That will tell you what you actually have to play with.
Like I said, I put on a 2 inch lift and have been running my stock length shocks for a number of years. I don't off road much and haven't heard/felt/or had any problems.
Denny
Old 12-07-2018, 09:17 AM
MD_7.three's Avatar
MD_7.three
MD_7.three is offline
MD_7.three is starting off with a positive reputation.
I'm in your boat being 2WD and I've yet to pull the trigger on the spacers...seems we don't have much for options other than those or a full 6" kit...I'll be following closely to see how it works out for you! Post some pictures!
During my research the dual axis adjustable caster bearings were also coming up as a required addition...there were more than a few that referenced having to do some work on the knuckle with a grinder as well
Old 12-07-2018, 09:56 AM
L-ight
L-ight is offline
Denny
Good to know. Yea I don't offroad at all unless going to the beach is offroading lol?
Yea I went ahead and purchased the moog adjustable caster bearings. I am thinking I will be ok getting by with the new Bilstein 4600 shocks up front. I can def provide pictures. I am just scared that I may have to grind some of the knuckle down, but I doubt it.
Old 12-07-2018, 10:06 AM
MiamiPSD's Avatar
MiamiPSD
MiamiPSD is offline
MiamiPSD is starting off with a positive reputation.
The 4600's will work. About grinding, check out: To grind, or not grind thread.
https://www.ford-trucks.com/forums/8...-question.html
Old 12-11-2018, 10:58 AM
L-ight
L-ight is offline
I will be tackling this job this Saturday. I just hope the alignment shop (Firestone) will know how to adjust with these adjustable camber bushings.
Old 12-11-2018, 12:41 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
The thread linked above includes a picture of my shock extension.
I'm running a 2" front lift.
New bushings for sure!
Knuckle grinding... I HAD to do it, little by little, several times to gain full clearance.
Alignment for sure!
Shock extension for sure!
ALTERNATIVE... get a new set of front springs which have no sag and provide any additional lift you want to achieve.
Old 12-11-2018, 12:58 PM
beef tits
beef tits is online now
beef tits is gaining momentum as a positive member of FTE.
I wouldn't grind parts of your truck away. Ditch the ebay lift and get a proper set of springs.
Old 12-11-2018, 01:55 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Yes, for 10 years now.
https://www.ford-trucks.com/forums/9...ml#post8492932
Stewart
Old 12-11-2018, 02:28 PM
MD_7.three's Avatar
MD_7.three
Originally Posted by Stewart_H View Post
Did anyone ever figure out the rhyme or reason for who had to grind vs not grind? specific to certain years? E99 any different than 99.5-03? One brand of dual adjustable bearing vs another?
I've been looking at a set of TufTruck HD coils since I know my springs are sagged at least 1" from stock...do you think those are enough to get back to level? Anybody running these? Any grinding?
Old 12-11-2018, 02:40 PM
L-ight
L-ight is offline
Alignment for sure!
That is what worries me is the grinding. As well as the shocks. They are pretty much brand new, but others have ran oem shocks with a 2" level kit without any problems. New springs doesn't seem like a bad idea. Would I still need an alignment? Bit more pricier though.
Any recommendations?
Sweet! What all did you have to do?
Old 12-12-2018, 10:51 AM
F250_'s Avatar
F250_
F250_ is offline
I discovered the need for grinding only after having everything installed and aligned, and found my ball joints not surviving long. On my first ball joint replacement, I noticed scrub marks between the knuckle and c-frame (where the ball joints mount). Choosing to focus primarily on the heaviest of those two pieces, I did some minor smoothing on the back side of the c-frame where it had been contacting the knuckle face, and noticed that the point of contact on the knuckle face was where the cast mold seam sort of slightly bevels outwards towards the c-frame. That "proud" bevel is what I flattened, very carefully, and even took a coupe of years and two sets of ball joints to get the gap where there was never any contact after alignment.
Is the 1" new springs enough? I'm honestly not sure since I'm not fluent with the original geometry dimensions. I just know that springs can be custom made for whatever height you want to achieve, btu I can;t tell you the specific process for specifying the new coil spring geometries.
As for the shocks, Different brands of shocks have different travel dimensions. I know that the Bilsteins I initially ran after installing the spacers were topping out when I hit a sudden pot holes or similar. Another member even experienced a broken shock as a result of the exact same travel limitation due to the rougher roads he used on a daily basis. He is the one who came up with the bolt extender on top of the KYB shock to obtain the correct travel capabilities (because the extender allowed the shock to "rest" in it's near-center position instead of "near the top" of it's travel range). I simply followed his example and have had zero issues ever since.
The grinding solved my ball joint life issue. Am I happy about having had to do the grinding? No. Do I believe that I removed enough metal to compromise the strength of my front end? No, not at all for my road princess driving activities, and as long as I'm not getting into slick wet stuff, I'm confident to take my truck anywhere I believe that the 2wd format will support.
The shock extenders have given me a better ride, and I don't feel the shocks topping out the way the Bilsteins used to.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
