Trans. Control switch problem #23fuse keeps blowing
Does anyone how to fix my 1999 F150 4.2l overdrive problem. The under hood #23 fuse keeps blowing and when , it does the truck won't shift and the overdrive indicator light flashes.
You don't have an "overdrive problem", you have a fuse F23 problem.
The most common cause of a blown F23 is due to wiring damage from recent maintenance or repairs, most often related to the wiring harnesses for the O2 sensors getting on the exhaust and melting.
