Carry a spare bearing
If you are not doing so already. Carry a spare wheel bearing in your rig. I found this out the hard way. I could have been back on the road in less than an hour, but instead I had to limp it to a trailer shop in the middle of no where that took about three days to get the part and fix it. Granted they had to buff the axle to fix the medal on medal groves it caused too.
I don't necessarily see this as an either/or decision set. Perform proper maintenance on your trailer, AND carry spare inner and outer axle bearings (and seals). I would pack the spare bearings with the proper grease beforehand to make roadside swaps as fast and simple as possible, since this sort of problem invariably happens at the worst possible time - heavy traffic, inclement weather, etc.
Two plus decades ago, after dealing with a failed bearing, on a Sunday no less, I decided to carry pre-packed spares. After all, this wasn't my first failed bearing. So, a box of packed bearings and seals for every trailer we own.
To date, I've haven't used the any of the spares! But no way do I dare travel without the spares...they must have some sort of magical powers!
There are also complete kits available with grease, parts and such for the complete assembly. I carry one of these in my trailer as you never know what will fail and I want to be ready and get back on the road. These are usually more expensive than buying the parts yourself but you can find them rather inexpensively if you look often and hard enough.
Received 6,629 Likes
on
How do I figure out which bearing _kit_ I need for my axle? I have a picture of the tag from my axle so I know it's a Dexter D52 axle, 5200 lb. I have the Dexter parts diagram that has individual parts listed on it. I found a kit on the dexter web site that matches the individual part numbers but the title of the kit says it's for a 6000 lb axle.
The kit is part number K71-719-00, about 3/4 of the way down the page. $57 per axle
https://www.dexteraxle.com/products/...nents/bearings
Dexter Parts Online has a kit for half the price: BEARING KIT, 15123, 25580 BEARINGS, 10-36 DOUBLE LIP SEAL ID 2.250, 1 WHEEL
The kit doesn't provide numbers for every part so I don't know that it's an exact match.
on
I haven't had my bearings apart. At least, not me personally. The service shop did the bearings two years ago as part of the inspection I had them do when I bought the trailer from a third party.
I don't like leaving a job half done. I would have to pull everything apart, get the numbers, order it and once everything came in, put it back together. This would all have to happen at the storage lot.
I was thinking of doing the brakes at the same time I did the bearings. Two birds, one stone sort of thing.
My whole problem with carrying a spare bearing...........for me, that is just making sure something ELSE goes wrong!!!!!!!!!!! I would carry that spare bearing forever and never have a bearing failure!
So, with that, how much and how many spare parts does one need to carry?
I go back to my statement of regular maintenance and inspection of everything I can.
I always carry a spare set of bearings and this year it paid off. Despite having all the bearings replaced this year on our travel trailer, it appears one of the new bearings was defective as it failed on our second trip out. It was on a long weekend, and I was able to pull over on an exit ramp off the highway but was out in the middle of nowhere. If I did not have this bearing with me, I would have been stuck for a couple days due to the holiday, but luckily enough, I was up and running again within two hours. I just consider it cheap insurance.
I carry a smattering of things in case of emergency. Here is a short list and most of this fits in a small bin in a hardly used area of my trailer:
-bearing set
-special items for bearings: sandpaper, special tools, etc
-zip ties
-gorilla tape
-pex adaptable fittings and a small section of drinking water safe tube.
-plastic and metal epoxy
-wire and terminals, splices.
I usually have a small small bag of tools with me in my truck.
The kit has come in handy many times not just for me but others with problems. This is enough material to fix any common foreseen issues but everyone needs different things.
-bearing set
-zip ties
-gorilla tape
My horse trailer use to only have brakes on one axle, when I added brakes to that axle I keep an extra hub (non brake), bearings, axle nut, retainer pin and cap in the back of tack storage area out of the way.
I've seen enough tire/wheel/hub assemblies come off of trailers that I figure a spare hub kit and tire wouldn't be a bad thing.
I've always just take my bearings apart when the parts store is open, see what i got and do a parts run if necessary. It's all pretty standardized when dealing with electric drums, oddball hardware is rare.
When i upgraded to disk brakes, I did put a spare hub on board, since disk isn't as common and needs ordering at most trailer supply houses. This wasn't because i was so much worried about failure on the road, but delaying a trip waiting on parts due to a pre trip inspection failure. I'd like to think I would do maintenance with plenty of time to source parts, but i know me.....
Mizuez
24
05-06-2016 08:31 PM
retiredsparky
06-23-2014 11:41 AM
lemonshindig
06-23-2012 11:58 PM
thrifty
06-06-2011 11:53 PM
JKBridges
1999 to 2016 Super Duty
03-05-2007 05:57 PM
