LH Tail light issue and SES light on FT - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 12-06-2018, 01:32 PM
CMPX2
CMPX2 is offline
CMPX2 is gaining momentum as a positive member of FTE.
Two issues with my 2011 Ex 4wd w/121k I could use some advice..
1. I replaced a cracked taillight and non-working brake/blinker bulbs this weekend. The light had some water in it so I sprayed cleaner in the wiring harnesses, but the lights still do not work. Any suggestions?
2. On the few occasions I have to floor the gas pulling into traffic, my engine light blinks for about 30 seconds. Other than this, it runs ok. Oil was changed this weekend and I'm getting 14 mpg mixed driving.
Old 12-06-2018, 02:21 PM
seville009
seville009 is online now
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
I don’t know if it’s the same on the Ex, but on my 2006 F 350, both reverse lights went out towards the end if last winter. Turns out the bulb plugs into a socket, which in turn plugs into another socket. The sockets that the bulb plugs into were corroded; bought new sockets at Autozone and they work fine now. Also put in LED reverse bulbs; significantly better than the oem bulbs I had in there.
On the engine light issue, no answer, but sounds like it might be “starving” for something. I’d check the air filter, maf sensor, and fuel filter as a start at least.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
