2000 F350 7.3L Injector Suggestions
It depends on what you want to do with the truck and how much you want to spend. Do you have emissions to deal with? Single shots will require a tune to get them to run efficiently. I went with Rosewoods 140’s in my E99 because at the time I didn’t think I would want bigger and I was dealing with EGT’s issues that I would find out was a plugged CAT. If I ever pull them I’ll probably look at 160’s but then I’m probably gonna need a turbo upgrade which means more money.
Upgrades lead upgrades that that lead to upgrades that leave the wallet empty. Research twice open wallet once.
I’m not looking for a racer or to leave coal on the windshield for the guy behind me. It’s a daily driver for now and I tow a trailer on average about 200 miles a month. So I definitely need something that I can tow a load with and not have to worry about it. I also don’t want to put 2gs into injectors. And I live in Commiefornia, so yes, I have emissions to deal with.
That's odd, because in the short conversation I had with him about rebuilding injector bodies, he mentioned nobody was re-machining the poppet seat in the body.
I'd suggest 160/0 the basic IH single shot upgrade. You'll need a tune flashed on your PCM, or a tuner (TS, Hydra, DP Tuner) to replace the Edge. Those injectors are for the IH version of the engine when installed in the medium duty line like tow trucks. In stock all across the fields of waving grain, if you're on the road much. An additional chunk of fuel to get the load moving but nothing that will be noticeable at smog time with good tunes.
Any single shot injector will require a tune to run properly. Your split shots can be rebuilt and perked up with better tunes, but if it were me needing new injectors I'd put in better hardware then tunes to match.
F-ing nightmare as all the planets lined up and had nothing but issues (injector work took a lot longer than expected, didn't even get it running until after smog was due, tuner was having in-house issues, and the smog station tech was a little rough).
Long story short: Hydra was not an issue and the tech spent 95% of his inspection time under the hood. That was lucky as I don't think the MODIFIED STOCK tune flashed on my PCM would pass the Snap Test. PHP did hook me up with an emissions tune that is driveable. Just to make sure I could drive on it if I had to I did get up to 40mph without any issues (light on the throttle) in case I was unable to put the switcher head back on before departing after the test. I'm not excited about spending more money to have my PCM re-flashed but once I get my oil leaks fixed I'm going to re-visit what tune I should have on my PCM for driveability and smog-ability in a pinch if I have to pull the Hydra in the future. I've got a year to figure that out so that will be a project next year.
Short story long: https://www.ford-trucks.com/forums/1...l#post17860313 (it starts at post #30 and is peppered in there after that)
GH and PHP did say that they were surprised that their Heavy Tow / Modified Stock tunes didn't pass muster for a Snap Test. They might have but at the time (brand new injectors) I wasn't going to risk it.
Before buying anything other than stock be sure to talk to your preferred tuner first. I have 160/30s and I am told they are harder to tune than say 160/80s. You could always purchase a 160/80 and de tune them so they run like 160/0 but with the 80% nozzle you can drop all of the fuel faster.
I have a clean tune flashed on my PCM and there’s absolutely nothing you can do to get smoke out of it. It’s definitely slow in that tune, but still faster than an 6.9 IDI.
I guess I need to update my signature. Jody at DP flashed it on there for me at a live tune session, but I’m running a Hydra now with emailed tunes. When I had the 38r, max boost was 12psi in that tune. With the SXE it’s now 18, so it’s drivable.
MikeSDK
20
03-09-2012 03:43 PM
