C6 SHIFT ROD GROMMET? BUSHING? - Ford Truck Enthusiasts Forums
Old 12-05-2018, 10:36 PM
72CC428
72CC428 is offline
72CC428 is starting off with a positive reputation.
Question C6 SHIFT ROD GROMMET? BUSHING?
I need the grommet or bushing/clip that goes in the small hole on this shift arm. I have found some but they are for the MT shift arms. They say they're for both but the one I had was plastic and it was a clip type that locks the shift arm to the shift rod. Anyone know what the part is called and where I can order one.
Old 12-06-2018, 04:23 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
Is this for a manual or automatic?
Old 12-06-2018, 12:08 PM
72CC428
72CC428 is offline
Question
Hey Gary. Nice to hear from you. It's a C6. They say that the bushings for the MT work for both, but the bushings for the 3sp MT arms don't look anything like what I took out of mine. It broke so I tossed it not knowing I would have trouble finding or even IDing it. The one I had was plastic.
Old 12-06-2018, 04:51 PM
Dans72
Dans72 is offline
Dans72 is starting off with a positive reputation.
bushings
Kickdown Rods Galore & More
He makes all kinds of shift rods and has Delrin bushings.
Old 12-07-2018, 11:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
EOSZ-7341-B (replaced C8OZ-7341-A, C9TZ-7341-A, D5AZ-7341-C) .. A/T Nylon Shift Lever Bushing / Available from Ford
1969/91 F100/350 all A/T's // Misc 1960's/80's FoMoCo Passenger Cars. This bushings snaps into the shift arm on column & trans.
1965/72 F100/250 3 M/T used rubber bushings/insulators on the column levers.
Old 12-07-2018, 09:33 PM
72CC428
72CC428 is offline
Thanks Dans72. One more site in my favorites!
Old 12-08-2018, 12:17 PM
resonateur's Avatar
resonateur
resonateur is offline
resonateur is gaining momentum as a positive member of FTE.resonateur is gaining momentum as a positive member of FTE.
Local auto parts store in the HELP! Section. They have an assortment pack as this is one of the standard size bushings. Good luck getting it in....I had to mock up a “press” with a block of wood, hose clamps and C clamp....it was so tight trying to get it to snap in.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
