Here's to kicking a dead horse...351w build questions
Hello everyone! I have been lurking for months and finally joined up today, looking forward to learning even more than I have in the short time I have been reading!
I have read a lot of build threads but have had trouble finding
one that's specific to my setup and goals. The truck (single cab long bed 2WD) is MAF and EFI. I will be getting linked lifters for a roller cam. I do plan on upgrading fuel system, pumps, lines, injectors.
I'm wanting to get close to 350-400hp at the wheels N/A out of this engine and needing some guidance on the next things I need to buy. Wanting to keep it street friendly as possible. Pump gas for sure even if its premium. I do not want to go with a stroker either. I'm planning on spinning it around 5,700-6,000
So far I have:
block freshly machined.040 over
fresh stock rods with ARP hardware
polished stock crank
AFR 185's with 72cc
Needing advice on:
pistons
cam (prefer a retro kit)
intake (thinking trickflow?)
Not trying to come off rude, just trying to get most questions I see asked on build threads answered and out of the way to help get the best advice and recommendations.
So far I have:
AFR 185's with 72cc
Needing advice on:
pistons
400whp is going to be very difficult under 6000 rpm with stock cubes, my suggestion is a stroker....even though you said you don't want to stroke it.
Compression ~10.5:1 on 93 octane will be a must.
Head choice is good, you'll need a cam 220/220 + duration....but what you intend to do with the truck is the real ticket to a cam recommendation.
on
Add a larger MAF and a tuner to that list.
No... you need a full base circle cam which means you need to start with a roller block.
Good choice there.
The motor in there now has a roller cam in it... unless you're not using it for the rebuild?
What transmission? It could absorb as much as 75-100hp which means the motor must be in the 500hp territory. Making that much power street friendly in a pickup is a bit of an unrealistic goal.
Nice heads but those chambers are way too big, you need compression to have any hope of making your goals so drop that to 58cc. Cranks and rods also need to be forged as this will be a spooler.
Good choice there.
Good choice there.
I have a tuner already waiting on me to get it together he is very familiar with Ford efi and well known in the sbf & mustang crowd around here.
transmission is a e40d
As far as the heads I already have them with that chamber so I was hoping in being able to select a piston to get the compression right?
This is my first build and still have a lot to learn. I didn't want to order the next parts without seeking advice. So if I lower my expectations to 300rwhp would that be a more realistic goal? The primary use of the truck will be to cruise around, go to car meets, and have some fun on Saturday nights.
This pretty much says it all. This build is about fun and acting stupid. Why pretend otherwise?
Your chamber size is better suited for a stroker. With a stroker you can grow your engine to fit those heads. With aluminum heads, if quench is set up right, you can run higher static compression with lower octane and less detonation. With a roller cam, and expert cam choice, you can cut your dynamic compression at low rpm to control detonation at lower octane.
If you are going to run 100K miles, lower octane will pay for everything. Sell your rotating assembly, and block, and get a stroker. Start with a roller block if you don't have one. Most people won't spring for the heads. Build the engine for the heads.
You didn't say anything about headers, get headers.
You won't destroy anything unless you can't control the stupidity.
Death is too good for street-racers.
So I'm leaning more towards a 393 now, due to the fact that I could at least use the rods I have. I have already had them freshens up and ARP hardware installed, so would like to use them, the crank was polished but it wasn't too much money so I wouldn't be mad about not using it. What kind of numbers could I expect with a 393W and my heads? Also, would I just get 302 stock replacement pistons that fit my bore?
https://www.summitracing.com/parts/s...view/make/ford
1300ish before tax and shipping. 408 stroker will be about 10.5 to 1 with your huge chamber heads. Then a decent cam and tune, and you're killing tires all day.
Also, most stroker kits come with forged pistons and a cast crank...perfect for high compression low rpm engines such as the one you'd like to.build. A compression of 10.5:1 with a 393 or 408 would be a very fun driver with the 185s and a 6000 rpm redline. 350whp would be easily achievable, with more than comfortable driving manners and tire shredding torque. Cam should still be 225ish +/- a few degrees in duration, wide lsa 112+, .550 lift minimum to work well with your rpm goal. Don't be afraid to use a conservative cam either, the risk of going too far is much greater than going too small in this instance, it will be a runner no matter what with the head and bottom end combo.
You will need to work with a supplier to provide appropriate piston for compression ratio if you want to use your heads. I haven't done much combustion chamber work on any set of afr's, as they are quality pieces already designed with attention to detail, but if there are cnc ridges or valve shrouding of any kind....now is the time to sand the ridges and polish the chambers, chamfer the combustion chamber edges, then measure the combustion chamber before selecting piston. If they've been milled at any point, chances are you will need to get rid of the sharp corner at the edge of the combustion chamber at the very least. I'm not a fan of dome pistons at all, if you can't achieve 10.5:1 With flat tops, i would mill .030 off the heads, measure combustion chamber, and recalculate compression using flat tops or small dish.
460jared96
101
04-03-2019 11:00 PM
CaptainJack_7
09-14-2014 01:41 PM
Shawn7240
02-05-2012 07:34 PM
NoAZ'68
12-06-2003 11:37 AM
