Throwing in the towel on oil leak - Ford Truck Enthusiasts Forums
Old 12-05-2018, 12:32 AM
bman661
bman661 is offline
bman661 is starting off with a positive reputation.
Hello All!
After replacing o rings like crazy I cannot get this 01 f250 to stop leaking (new turbo pedestal and orings, ebpv delete, new HPOP hoses, new orings on ipr, drain plug on HPOP, new hose fittings on HPOP and cylinder heads, new ICP) damn thing seems to be leaking worse!! 😡 I could see it leaking from the HPOP fittings took it apart again new orings and still leaking. Maybe it needs to be tighter but I read some horror stories on over tightening... So I think Iím going to take it to the shop to find and fix the leaks does anybody have a rough estimate on what itís going to cost me?? May change my mind and tear it apart again if you guys think itís going to be outrageous!
Old 12-05-2018, 06:12 AM
truck7575's Avatar
truck7575
truck7575 is offline
truck7575 has a good reputation on FTE.truck7575 has a good reputation on FTE.
My HPOP case had a crack in the housing and it was very hard to figure out that is what it was...
Rick
Old 12-05-2018, 07:57 AM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
My prediction at a shop is one arm, one leg and no better results than you can obtain yourself. On the HPOP fittings you also need to use loctite green, I don't know if it helps seal but with the low torque applied it stops them from coming loose.
Old 12-05-2018, 09:11 AM
RigCity
RigCity is offline
RigCity is starting off with a positive reputation.
Might as well do the master o ring kit. Iíve been going section by section and it will fix that problem than start another leak or a previous leak will leak more now that the other one is fixed. How much oil is under the truck? Mine has gone from a puddle to a few drops. And your sounding concerned of how tight stuff is are you using a torque wrench?
Old 12-05-2018, 09:13 AM
RigCity
RigCity is offline
Also if you clean the valley and put some shop towels in there that could help let you know if itís from the front or back of the engine
Old 12-05-2018, 11:30 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
According to Corey at CNC, green Loctite is a no-no....and I can attest as to why. If you have to remove those fittings at any time, it can and will cause the threads to come with it. It's soft aluminum. There is a proper Loctite that sets more like a Nylock, but I took his advice over the summer and just used the o-rings. No leaks yet.
As far as a shop, I would highly advise against it. You can do this man. We have all been through it. Take a deep breath and start from square one and GO SLOW. That is the biggest reason I see for making mistakes or overlooking a problem. Let us know.
Old 12-05-2018, 11:37 AM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Use tracer dye.
Old 12-05-2018, 12:53 PM
bman661
bman661 is offline
Ok you guys have convinced me to tear it apart again, I did use a torque wrench I torqued the pump discharge fittings: 25 ft/lbs, head fittings: 19 ft/lbs. that is what I found with a search, maybe those are incorrect? I suppose worse case scenario I can slap a new HPOP in for cheaper than a shop would most likely charge me to replace o rings. it seems as though the fittings in the HPOP and in the head are the culprits, but ill have to clean it really good again to be sure. Now I didn't take the pump out I suppose I should and repair the non serviceable plug and the main gasket, it doesn't appear to be leaking out the non serviceable plug but I don't want to do this again. Any other suggestions while I have it all apart for the 4th time LOL? fuel bowl too i suppose?
Old 12-05-2018, 04:26 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Here's a trick I use to find oil leaks of mysterious origins: take a paper towel, cut it into about 2" strips. Then twist each strip until it's pretty tight, about the diameter of a drinking straw. Wrap the twisted towel around each of the suspect fittings, using a zip tie, twist tie, or clothespin to hold it in place (clothes pins work for smaller fittings, like fuel). Drive it for a bit and remove each towel to see where there is oil - if you're lucky, it will be one you can access without removing too much other stuff to get to it.
I've also found that you can take the twisted paper towel and wet it with water, wrap it around a piece of PVC pipe similar in size to your target test subject, and let it dry - that will help getting it to conform if you're in a tight area.
Also, the things in the link below come in really handy when removing HPOP lines, the head plugs, or anything that is going to drop a lot of oil. I line the valley with them and stuff some under the HPOP, plus make sure the valley drain is plugged with them at the aft end of the valley - it keeps the oil from dripping down the side of the engine and making a mess that takes some time to clean.
Amazon Amazon
Old 12-05-2018, 04:42 PM
onelionhunter
onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
I actually had to replace the fittings on my HPOP to get them to quit leaking, I fought them 4 times before I got the new ones. I think I got the new ones at Diesel Orings. I did, linky High Pressure Oil Pump Discharge Hose Fitting - High Flow 1999-2003
Old 12-05-2018, 04:44 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
You sure it's not the front head on the oil cooler? I've had that leak get up and into the valley before.
Old 12-05-2018, 04:47 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Your first step should be to clean the **** out of the valley and top side. Use cut Simple Green. Apply it to a warm, not hot engine. Rinse with just hose pressure. Soak the valley heavy with Simple Green and then flood the valley thoroughly with hose water. Let it dry completely before you start it and check for leaks. You got this bro.. No shop.
Old 12-05-2018, 05:08 PM
UcaN
UcaN is offline
UcaN is gaining momentum as a positive member of FTE.UcaN is gaining momentum as a positive member of FTE.
FYI..... i was going through a similar issue just last week. I could not find the leak until i cleaned the valley well. It was coming from the (check valve plug) on the block. The one that is just below and to the drivers side of the HPOP...
Check and see if that might be your problem. I was lucky in that i snugged it up and the leak stopped, but i am sure i will have to take that plug out and reseal it in the near future.
I guess now is the time to ask if anybody knows if the HPOP has to be removed to get that plug out to have it resealed.
Old 12-05-2018, 06:51 PM
bman661
bman661 is offline
Thank you guys for all your help and information.... I am going to give it a whirl!
Old 12-05-2018, 06:56 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
good luck to you. seems everytimei fix something another thing starts leaking, endless projects forsure. love the 7.3 tho.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
