Let's see your steps to access the bed behind the cab. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-04-2018, 11:39 AM
2019er
2019er is online now
2019er is starting off with a positive reputation.
Since the running boards aren't long enough. Do people carry something in their truck when they need to reach something in the bed behind the cab? Or does everyone climb up in the bed to get to stuff?
I was looking at mine, seems if they were longer, back to almost the wheel well, or even a foot or two, could be used as a bed step for this purpose.
Old 12-04-2018, 11:42 AM
Tricon's Avatar
Tricon
Tricon is offline
Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.
I just step on the tire.
Old 12-04-2018, 11:50 AM
xxxsherpa
xxxsherpa is online now
xxxsherpa is gaining momentum as a positive member of FTE.xxxsherpa is gaining momentum as a positive member of FTE.
OEM extended running boards.
Old 12-04-2018, 12:00 PM
xxxsherpa
Another one...its the black piece at the rear door, extends to the wheel well opening.
Old 12-04-2018, 12:03 PM
BowtieConvert
BowtieConvert is offline
BowtieConvert is gaining momentum as a positive member of FTE.
I have the Amp drop down step in front of the rear wheel. It works pretty good for this old fat man.Can't seem to be able to post a pic though.
Old 12-04-2018, 12:27 PM
PentaPop
PentaPop is offline
PentaPop is gaining momentum as a positive member of FTE.
Another vote for the factory extended boards. I use them all the time for digging around in the tool box.
Old 12-04-2018, 12:50 PM
77mmbass's Avatar
77mmbass
77mmbass is offline
77mmbass is starting off with a positive reputation.
I also have the OEM. I like then.
Old 12-04-2018, 01:13 PM
ShadowGrey
ShadowGrey is offline
ShadowGrey is gaining momentum as a positive member of FTE.
We almost ordered ours with the power steps and then decided at the dealership the day of ordering to get the extended steps. We will know in a couple of weeks...I hope.
Old 12-04-2018, 01:16 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Alaskan_Warbird has a good reputation on FTE.Alaskan_Warbird has a good reputation on FTE.
Do you have a part # or a link to the one you have? I'm considering doing something similar.
Old 12-04-2018, 01:37 PM
2019er
Do the extensions work for the OEM power runningboards? Stepping on the tire won't work for me. Dually. And the diamondback cover I will be installing will have the middle part that is fixed right about where the wheel well is. The part near the cab flips open, and near the tailgate flips open, but not the middle piece near the tires.
Old 12-04-2018, 01:48 PM
Sport45's Avatar
Sport45
Sport45 is offline
Sport45 is starting off with a positive reputation.
Luverne O-Mega II wheel to wheel boards. Wish they were a tad lower, but they get the job done for me.
Old 12-04-2018, 01:50 PM
BowtieConvert
Here you are, sir.
AMP Research | Official home of POWERSTEP? | BEDSTEP® | BEDSTEP2? | BEDXTENDER?HD
Old 12-04-2018, 02:05 PM
bk4gbay's Avatar
bk4gbay
bk4gbay is offline
bk4gbay is starting off with a positive reputation.
ICI Magnum RT steps wheel to wheel if you want a unique look.
Old 12-04-2018, 02:19 PM
Alaskan_Warbird
Thanks! Reps sent.
Old 12-04-2018, 02:58 PM
xxxsherpa
I think with the DW you are out of luck on the extended boards. I've been wrong before.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
