Stock Suspension with 35 Show your Trucks - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-04-2018, 01:32 AM
vinnie_p
vinnie_p is offline
vinnie_p is starting off with a positive reputation.
Im looking to purchase new rims and tires. I would love to fit a 35 tire but don't want to do a leveling kit or I can't park in my garage. Living in the Great White North so garaging a diesel in the winter is better than plugging in. Wondering if its possible with no trim or cutting. Im looking at Fuel rims or Sota with a Nitto Ridge Grappler or BFG KO2. I have the snow plow package if that makes a difference. Recommendations????
Old 12-04-2018, 06:55 AM
ka_EMT
ka_EMT is offline
ka_EMT is starting off with a positive reputation.
I just put on 35x12.5R17 General X3s on 17x9 Raceline Defenders with a 5" backspacing on the stock suspension yesterday. So far I haven't had any issues with rub. They Stick out just a little bit, nothing obnoxious.
Old 12-04-2018, 07:48 AM
vinnie_p
vinnie_p is offline
Looks sharp!!! That is the way it should come from factory. Skinny tires drive me crazy.
Old 12-04-2018, 08:11 AM
homerj
homerj is offline
homerj is starting off with a positive reputation.
295/65/20 on 9 wide +12
I know ou said 35’s but these are taller and narrower
Old 12-04-2018, 08:18 AM
Section179
Section179 is online now
Section179 is starting off with a positive reputation.
Stock height on 37s... no body rub whatsoever at full articulation, rubs sway bar and radius arms. Iím having a sway bar made and going with aftermarket radius arms to eliminate that rub...
not what you asked to see but figured itíd give you full confidence on 35ís.
Old 12-04-2018, 09:16 AM
Haftahunt
Haftahunt is offline
Haftahunt is starting off with a positive reputation.
35x12.50 BFG all stock
Old 12-04-2018, 09:36 AM
st1nn3tt's Avatar
st1nn3tt
st1nn3tt is offline
st1nn3tt is starting off with a positive reputation.
295/65/20 Trail Grapplers
Old 12-04-2018, 11:59 AM
Tricon's Avatar
Tricon
Tricon is offline
Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.Tricon has a good reputation on FTE.
35's fit no problem stock, not even close to rubbing.
Old 12-04-2018, 12:20 PM
saucemann's Avatar
saucemann
saucemann is offline
saucemann is starting off with a positive reputation.
Which aftermarket radius arms are you getting to not have rub on factory wheels with 37's?
Old 12-04-2018, 03:52 PM
vinnie_p
vinnie_p is offline
37's!!! on stock wow.
Old 12-04-2018, 04:18 PM
Section179
theres a whole thread comparing radius arms, hereís a post with pics of PMF and Lewis:
https://www.ford-trucks.com/forums/s...8&postcount=11
Iíve spoken with both manufacturers and the brackets are pushed over to increases clearance. I havenít fully settled my mind in which to go with.
Carliís fixed radius arm also has the indentation placed to support larger tires and is an option, but Iím set on adjustable.
Old 12-04-2018, 05:00 PM
VA13FX4's Avatar
VA13FX4
VA13FX4 is offline
VA13FX4 is gaining momentum as a positive member of FTE.
do you have any pics looking straight at the front and/or rear?
Old 12-04-2018, 08:32 PM
DangeloD
DangeloD is offline
DangeloD is starting off with a positive reputation.
35x12.5x20
Old 12-05-2018, 12:13 AM
vinnie_p
vinnie_p is offline
Originally Posted by DangeloD View Post
35x12.5x20
What rim and offset did you go with? looks great!!!
Old 12-05-2018, 04:38 AM
Bashlin_'s Avatar
Bashlin_
Bashlin_ is offline
Bashlin_ is starting off with a positive reputation.
35x12.5/18 Stock wheels.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
