Intermittent no start ?
Old Dec 1, 2018 | 07:13 PM
NICKSAN's Avatar
NICKSAN
94 E150, Club Wagon. E4OD 5.8. 132,000 Miles.
New Battery, New Plugs, New Wires. Rotor and cap are not very old. IGM is only a few years old, (not that it could be faulty) IAC valve only a few years old. New fuel filter.
A few months or so ago the van would not start, took a few cranks then she started up.
I dismissed it as a fluke.
Took it on a long trip a few weeks ago and ran like a champ with no issues starting.
Today, I was very far from home and it would not start, Turned over great 6, 7 times, starter cranking away, but getting this loud hollow sound out of the exaust. I put my foot on the brake, put the key to acc. and cycled the shifter all the way up and down through all the gears and it started right up.
As soon as I got home, turned it off, turned the key and it started right up.
This is my daily driver. I drive it every day to work and all over.
Anyone have any advice on this one?
Old Dec 1, 2018 | 10:01 PM
vandemonium's Avatar
vandemonium
I had a similar problem which I threw a few hundred dollars worth of parts at, only to find out I had a bad ground strap somewhere (shop fix, guy didn't say where exactly).
It might be worth a look.
Old Dec 2, 2018 | 04:14 AM
JWA's Avatar
JWA
The ground strap could certainly be an issue---rethink the times it won't start first time recalling the weather that day. If the won't start thing pops up at certain temperatures etc that might be a suggestion something electrical looses contact with temp changes.
Could also be a fuel pressure issue----has that been checked?
Old Dec 2, 2018 | 05:42 AM
NICKSAN's Avatar
NICKSAN
Vandemonim, Ground strap(s) could very well be the issue. I will give that a look over.
JWA, Have not had the fuel pressure checked but am taking it in for other work, I will see if they can check the pressure at the same time.
The last time it had a hard time starting, the temps were high and the van was hot. This time its cold out and van was sitting for a while.
Thanks.
Old Dec 2, 2018 | 06:57 AM
HandyAl's Avatar
HandyAl
Hi,
A few years ago I experienced a similar situation with my 94,E350,5.8. It all came down to the ICM. The weird thing about it is that I had to tried a few ICM's until I found the "right one" . Is it the grey module or is it the black module? When I did my research, I found out my truck needed the black ICM. When I bought the black Motorcraft ICM and installed it, the truck did not start. I tried the grey Motorcraft ICM and the truck did not start either. I happened to have and new ICM which I had bought a few years back but never use and when I installed that one the van started. Go figure. It is a grey ICM . I bought it at O'Reilly. 80K miles later and that ICM is still running in my van. I tried to track it down base on the numbers on the part but not luck. My two cents. Good luck fixing your rig.
Old Dec 2, 2018 | 09:38 AM
econo93's Avatar
econo93
Since shifting thru the gears seemed to affect starting, I would look there. Maybe the Transmission Range Sensor?
Any codes?
Old Dec 2, 2018 | 11:59 AM
NICKSAN's Avatar
NICKSAN
HandyAl,
When I changed out the ICM several years ago I had bought one but dont remember the color but I knew there was a black and a grey one. I returned it to oreillys without installing it after finding out it was the wrong color.
I dont remember wich one I installed but It has been working ok since. Unless its going bad again.
Econo93, Thats what I was kind of wondering also. I am going to check it out.
Thanks guys.
Old Dec 2, 2018 | 12:40 PM
WarrensE350's Avatar
WarrensE350
Not saying this is your issue, but it's a possibility. My 96 7.5 started to do that out of nowhere... always kicked right over after a couple cranks, never failed to start. Then one day we went to the zoo (I doubt that matters though), and it cranked and cranked but wouldn't start. Did that several times; I thought I would be stranded. But then it fired right up. Started fine again for a little while after that but did it again occasionally. Finally, it just pooped out. It was the fuel pump. I swapped out the fuel injector pressure regulator at the same time because it was cheap, for good measure. I'm not sure if it failed and wore out the fuel pump, or if it was even involved at all, but I changed it anyway.
Old Dec 3, 2018 | 11:34 AM
turbogus's Avatar
turbogus
More than once, over the years I've found a situation where a mechanical gremlin would over torque the nuts on the starter solenoid, breaking the internal contacts, making for intermittent starting issues. The nut is large, but it's for continuity sake rather than torque. I've seen this on vehicles as late as '96's. This may not be your issue but it may be worthconsidering
Old Dec 7, 2018 | 07:43 PM
NICKSAN's Avatar
NICKSAN
Well, It did it again today and I was suprised because it happened again so soon. Same thing........ No start after several cranks, starter sounds good and lots of power I grabbed the shift lever cycled it up and down a few times and it started. I am going to look at it this weekend.
Thanks everyone for your suggestions.
Old Dec 8, 2018 | 04:50 AM
JWA's Avatar
JWA
I have no direct experience with the Transmission Range Sensor but I understand there is an alignment procedure needed to have it function correctly. I'm sure there's a tool or procedure for this---I've seen several YouTube videos where other DIY's have developed work arounds to this. Here's an example:
I hope its nothing more than a quick adjustment or tightening loose bolts.
Old Dec 8, 2018 | 10:25 PM
NICKSAN's Avatar
NICKSAN
Thanks JWA for the vid.
This morning I played around.......... Put it in N and it would start, then park and it would not then move the shifter up and down and it would start...
Drove it around and it started up evertime.
I checked the range sensor (or NSS switch) and nothing is loose or seems out of place, It was replaced about twelve years ago.
It could be bad. Considering changing it, Just to see if it is the culprit.
Thanks.
Old Dec 22, 2018 | 06:58 PM
NICKSAN's Avatar
NICKSAN
I am reconsidering weather its the NSS because today It would not start and it kept making the typical GLUG,
GLUG sound while cranking, sounding like its struggling for Air or Fuel, But then it starts after letting it sit a few
minutes. Ive checked before and get no codes. (OBD1)
The fuel filter is only a few months old. I am thinking Fuel pressure regulator or the pump.
After 25 years and 230,000 miles the rubber parts have got to be deteriorating.
I dont know if checking the fuel pressure would show much since it starts most of the time?
Old Dec 23, 2018 | 05:38 AM
JWA's Avatar
JWA
"most of the time........." is never good enough for me---every time or something's amiss!
Even though the van starts and runs more often than not your symptoms strongly suggest low fuel pressure. Pressures on the lower side of the spec still allow the van to start most of the time but when too low it'll run rough until or unless the fuel pump begins to produce an acceptable pressure the engine requires.
You really really need to check fuel pressure that's available at the fuel rails---that could be the culprit here.
HTH
Old Dec 23, 2018 | 01:45 PM
NICKSAN's Avatar
NICKSAN
HTH
Yes, I am debating buying a gauge and doing it myself or taking it to the shop that works on it and bring along a new FPR. If it ends up being the pump I have to have them do it.
I know its not that difficult to check and replacing the FPR looks pretty easy as well I just have nowhere to work on it.
