Water pump and radiator leak
Old 01-17-2019, 07:24 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Originally Posted by Deuce40s View Post
Yes, that looks like where mine was dripping from. The drips followed all the suspension components before dropping on the ground so the point of puddle would vary. It looks like you might have an oil leak as well?
Yes, the upper oil pan has been leaking for the past 12k. Last time it was in for service I asked them to look at it. They cleaned the area and put die in the oil and said "no leak". It's much worse now so maybe they will finally do something about it.
Old 01-18-2019, 01:43 AM
brmpipes
brmpipes is offline
brmpipes is gaining momentum as a positive member of FTE.
Interesting my 2016 f-350 goes in tomorrow for the exact same thing.Could something be wrong with these pumps in the 2016 model year?
Old 01-18-2019, 01:44 AM
brmpipes
brmpipes is offline
I have 84000km on my truck at the moment.
Old 01-18-2019, 07:25 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
I wonder the same thing.
And.....what is it that fails that causes the coolant to leak? Is it a bearing seal or cover seal that loses torque?
Old 01-19-2019, 09:02 AM
brmpipes
brmpipes is offline
Got my truck back at noon yesterday. Invoice said water pump or seal leaking, remove and install. Free because of 100000 warranty. Service guy also stated the pump has 2 year unlimited mileage warranty on it also.
Old 01-19-2019, 09:21 AM
Sader's Avatar
Sader
Sader is offline
Sader has a good reputation on FTE.Sader has a good reputation on FTE.
Mine is a 16 also, recently had the water pump replaced due to a leak @ 22k. I now have another leak that has developed in the left front corner of the engine bay behind the headlight that I couldn't identify. It is random as to when it leaks, I am suspecting the radiator, it's leaking from an area that is hard to see.
Old 01-19-2019, 09:24 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
Thanks for the info. Was the pump replaced or did they just R&R the seal? Mine goes in Monday.
Old 01-19-2019, 10:58 PM
brmpipes
brmpipes is offline
Water pump was replaced according to the parts list on invoice.
Old 01-22-2019, 06:22 PM
mich905
mich905 is offline
mich905 is starting off with a positive reputation.
My 2016 is going in on Monday for the same issue. Waterpump replacement due to leaking. 56,800 KM
Old 01-23-2019, 06:37 AM
Deuce40s
Deuce40s is offline
Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.
A whole lot of 2016s coming out of the woodwork with poor seals.
Old 01-23-2019, 10:26 PM
capt caper
capt caper is offline
capt caper is starting off with a positive reputation.
Mine been fine. Got 115000 miles now.
Old 01-24-2019, 07:40 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
Yeah no kidding.
My service advisor called yesterday with an update. The water pump is leaking as well as the front cover, they ordered parts and should have the truck back to me this afternoon.
I recorded the following December 2017, quite positive it was the water pump bearing making the noise.
  #28
Old 01-24-2019, 10:09 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Interesting. Mine started making this noise on Monday, 01/21 and loud enough that I stopped to make a recording of it. This was the first start in the morning, I think temps were upper 30's.
The best I can remember, mine didn't make this noise prior to the primary water pump failing in 2015. It just failed. I discovered that issue walking out of the office one evening with a lot of my coolant on the ground under my truck.
After the thousands I spent on truck repairs in 2018, I can't wait to kick off 2019 with more truck repairs...LOL.
  #29
Old 01-25-2019, 11:40 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
That's the same noise mine made. Interesting enough it only did it for a week then never heard the noise again. It was low 30's when I recorded it, yours is easier to hear, I had mine idled up and first start after a cold soak.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
