Best Hay Hauling Trailer?
I haul a pretty decent amount of hay, have a 20+5 tandem dual big Tex gooseneck with mega ramps, leave them in upright position and you only need one strap versus 2, will hold 14 4x5’s, or 17 4x4’s. I used to pull it with a stock 2001 f250 7.3, now pulling it with a 2018 f250 6.2 with 3.73s. The 6.2 pulls it just as good or better than the 7.3 did. Just burns a little more fuel
Thanks for the pictures. Funny thing - I had just been looking at the web site of the Big Tex dealer about 100 miles away. I discovered what Mega Ramps are - that is the ticket! The one I was looking at on their site was actually 28' + 5 (Mega Ramps).
https://www.rollinontrailers.com/inv...-over-megaramp
Thanks for the info!
-Bob
-Bob
Thanks! It's actually a F-450, we did a 07 coil spring front conversion and the Super 60 axle stuck the tires out past the fenders.
Since the donor F-550 was also white we swapped fenders with the flairs rather than drill holes in the good original fenders.
We also swapped in a set of F-350 5600lb coils for a softer ride that also lowered the front a couple inches.
#30
It does balance nicely when fully loaded. The length can be prohibitive in some places, but being narrower and lots of clearance means you can take them places you could never get a flatbed gooseneck. They’re so much easier to load and unload, and you never have to strap it down, so it goes so much faster. For the conditions we’re usually hauling in, going 15 miles one way, I can easily make 3 trips with this hauling 11 at a time vs. 2 trips with a flatbed (ours hauls 14 max). And not needing a tractor to unload makes all the difference sometimes, too.
