Grinding/scraping noise from the front end.
#31
I’m not going to lie...I love having auto hubs. But I really worry this is going to be another poor design that Ford can’t easily fix. If slapping manual hubs on and capping the vacuum system solved it, I’d install them tomorrow.
Interesting that both Warn and Mile Marker stopped offering a manual hub conversion in 1996.
#32
#33
Gah, I have this just starting too. Second round. Called and I was told not til the end of January for the check valve to be in. So another part on backorder. She said the part number changed from FL3Z-3A788-A to FL3Z-3A788-B.Going to install the aftermarket one for now. Does anyone know if this and the IWEs are part of the 5 year / 60 mile? I'm at 44K on my '15
#34
I looked around some myself, doesn't appear anyone has some. After my troubles with auto lockers on a 250, I always made sure I ordered manuals on the rest of them. Sure wish we had that option across the board, it's not that difficult to twist the actuator.
There would be a lot to change out if they were available, wheels would be a big one.
#36
Well, the dealership just called and they “found a vacuum leak”. I’m having a bunch of other work done, so won’t get the truck back until Wednesday at the earliest. I’m really praying this fixes the problem.
And for those of you that asked, this TSB is covered under the 60,000 mile warranty.
#38
#39
Nope. I’ve learned not to ask the guys behind the service counter too many details. It’s hard enough for them to find recall and TSB info. I do need to confirm the Tech looked at the bearings (last few steps of the TSB) to ensure they didn’t stop mid-inspection.
#41
Just got a call from the dealership that my truck is ready. Sounds like they replaced just about everything. The valve and IWE system.
It’s nice and cold here, so tomorrow morning will be a good test. I’ve never had any repair on that system last more than a week, so if it’s not fixed then I’ll know soon.
Will report back in a few weeks...
#43
For what it’s worth, here’s the repair report. Can’t say for sure the truck drives better, but a small vibration in the brake pedal is gone. I thought it was from my A/T tires, but I hit the brakes hard a few times on my drive home and the tire sound is there, but not the brake pedal vibration. Fingers crossed...
#45
