Mild 390 build advice
Old 12-07-2018, 09:11 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
i have the H395p pistons 1.759 comp height in my 390 and c8AE-H heads , i run 87 /mid gas with no issues .
the h395p are inexpensive , my build was on a very tight budget .
  #32
Old 12-07-2018, 09:47 AM
MIKES 68 F100
I'll run it this weekend and post results , I'll run with the 256/262 & 262/268 as i already have them In my Cam folder for DD5
I have the HEI dizzy it is big and ugly , only good is replacement parts are available at every local Auto parts . so If something fails you are not stranded with parts on special order .
  #33
Old 12-07-2018, 12:50 PM
baddad457's Avatar
baddad457
baddad457 is offline
You're not stranded for parts with a Pertronix either. Keep a spare set of points in the truck, not that you'll ever need them afterwards. I ran Pertronix I, II and a Crane XR-1 many years and never had a failure.
  #34
Old 12-07-2018, 01:08 PM
baddad457's Avatar
baddad457
Originally Posted by the_hetz
. As someone else pointed out, the forged piston is also overkill in this power range.
Ha..."mild cam = 290* duration"...
The stock c8/d2 heads vary widely in combustion chamber size. I've seen 68-72 being most common ranges. If you got some that were 72 cc or maybe even some 74 cc outliers, that makes a world of difference. I quoted compression ratios above with a .050" gasket and a 68 cc chamber.
68-72 is the typical casting tolerance in any Ford head. 4 ccs makes about a tenth of a point difference in the comp ratio.
Just avoid louvered glass packs and get perforated. A turbo-muff isn't going to give you more power over a perforated glass pack on this planet. Just as importantly, stay reasonable with exhaust pipe size (2-1/4" rather than 2-1/2" +) for your rpm range.
Unless you let the muffler shop mount them backwards. That happens a lot, then mounted backwards, there's a whole lotta difference in power..
No, going forged is cheap insurance against a shattered hyper piston subjected to detonation
  #35
Old 12-07-2018, 03:38 PM
the_hetz's Avatar
the_hetz
the_hetz is offline
Reasonable compression is even cheaper insurance against a broken cast piston due to detonation.
  #36
Old 12-08-2018, 02:58 AM
baddad457's Avatar
baddad457
And how does that relate to a tenth of a point in the ratio ? You're nit picking here. I ran the stock 10 to 1's with 87-89 octane with two different cams and no detonation
  #37
Old 12-08-2018, 07:29 AM
the_hetz's Avatar
the_hetz
the_hetz is offline
First, a 290 duration cam is not a mild cam, something we keep going back to. This allows you to run higher compression. Even the 272 cam you mention is slightly bigger than what he is planning to go with. That's great that it worked out for you, but if you didn't measure everything then you really don't know where your comp landed, and you may have gotten lucky.
How do you get 1/10? Have you actually done the math? With a 10 cc piston, the difference from a 68 to 72 cc head goes from 10.1 ish to 9.7 ish. That's hardly nitpicking. Change that to a 19 or 20 cc piston and now we are in the 9 to 9.4 range: something much more appropriate for a cam that tight. This is *hardly* nitpicking. I just threw in a .050" gasket and there will obviously be some error in parts and some other variables to adjust slightly up or down from here. To truly know you would have to have everything measured.
It is not wise to push yourself to the edge on compresstion, especially on a mild build. There is no point.
Forged Aftermarket rods are cheap insurance against a broken rod. Studded heads and mains are cheap insurance. The list goes on and on. Once you add up all the cheap insurances, it is no longer cheap. For a build this mild, quit at the beginning and buy the correct parts.
I once did squats after binge eating Mexican. It worked out for me, but I don't recommend it to others because I know I got lucky and that the outcome would likely be disastrous.
  #38
Old 12-08-2018, 11:12 AM
baddad457's Avatar
baddad457
Maybe you should try doing math here. What cc the piston top volume here is irrelevant to a 4 cc difference in the head, the difference doesn't change. And funny you should chastise me on math, what with your spelling errors.
Forged rods are cheap insurance against a broken rod. Studded heads and mains are cheap insurance. The list goes on and on. Once you add up all the cheap insurances, it is no longer cheap. For a build this mild, quit at the beginning and buy the correct parts.
Well you've never run these cams I see. If you had, you'd know they are quite mild in a 390. The 272 in that Merc's 390 idled smooth as silk except when cold, even then you had to listen to hear the little lope it had. Ditto for that Cam Dynamics 290 grind. Don't know why you'd segue off into forged rods here. ALL Ford pushrod V8's had forged rods. You don't have to go all out in any build.
  #39
Old 12-08-2018, 12:00 PM
MIKES 68 F100
ok here's the results
run 1 with your specs (stock bore) and Lunati 256/262
  #40
Old 12-08-2018, 12:01 PM
MIKES 68 F100
run 2 your specs (stock bore) with Lunati 262/268 cam
  #41
Old 12-08-2018, 12:40 PM
the_hetz's Avatar
the_hetz
the_hetz is offline
I edited my post above to say *aftermarket* instead of *forged* which is what I actually meant. Thanks for pointing that out. The point I was trying to make is that there are many decisions where "a little more money spent is good insurance" and that it can add up to a cost that is no longer marginal over the course of a project.
My math is solid and not made up; I'm not sure what you have against it. Let me explain: I showed rough ranges for both a 10 cc piston with a 68 cc to 72 cc head (approx 9.7 to 10.1) and similar ranges for a 19 cc piston with a 68 cc to 72 cc head (approx 9 to 9.4). The 4 cc of head difference is neither insignificant, nor is it "only 1/10 of a point of compression" in either case. It could be enough to make or break the build. You may have had chambers at the high end or even above the 'spec' while his may be at the low end. Without measuring, play safe. In a mild build, play safe.
By the way, a 4 cc difference in head volume actually WILL affect the compression more significantly with a 10 cc piston than a 20 cc piston, but not much. This is not a point that I was trying to make before as it doesn't really become significant within reasonable bounds, but you seem to have brought it up. Change in cc is not a linear relationship with compression ratio.
Please be specific about my spelling errors and I can correct them. I do what I can to proofread, but there is a diminishing return on time spent trying to catch every single thing, especially on a cellphone. I did not "chastise" you; I questioned whether you did the math because the "1/10 of a point" claim was solid evidence that you had not.
Regarding the cams: NO, I have not run either, nor have I claimed to. I did not say the 272 was a big cam, I only pointed out that it was slightly wider than what he has chosen and is therefore a step in the right direction. This, combined with other variables (such as actual head volume) may be enough to make or break things. That is the point I'm trying to make. A 290 cam will allow a LOT more pressure to bleed off on the compression stroke which again could make the build work. Dropping this down to a 256 or even 262 is HUGE difference and makes it an apples/oranges comparison.
What did you use for intakes? How aggressive were the ramps on that 290 cam? A 290 cam with similar .050" specs to the ones at hand would be a pretty sluggish ramp/old design/not efficient. If it had big .050" specs then it is no longer mild (I noticed that you didn't claim the 290 to be 'smooth as silk'). All of these things affect cylinder filling and therefore pressure and therefore detonation characteristics.
What did your timing end up being through the RPM range and was it optimized for an old school, slow burn head?
  #42
Old 12-08-2018, 01:18 PM
MIKES 68 F100
I took a video of my truck idling and revs . I will post it later .
it is a smooth idle very little lope ,sounds great when on the Gas .
I have 2.5 Xpipe exhaust with flow master style mufflers exiting before the rear wheels
  #43
Old 12-08-2018, 01:48 PM
MIKES 68 F100
here's the video I took this Morning .
  #44
Old 12-08-2018, 01:50 PM
MIKES 68 F100
excuse the Chime in video , its my security camera alerting me on my phone that someones by my truck .
  #45
Old 12-08-2018, 06:40 PM
460jared96's Avatar
460jared96
460jared96 is offline
The advice given was that a small cam and the flat tops (very high compression) together is a *terrible* combination. That high of compression will require a big enough cam that stock heads are out of breathing room where it starts to shine, and the bottom end will start to die...the worst of both worlds.
You NEED pistons with a dish and a modestly larger cam (up 1-2 more sizes). Even the 268/276 cam recommends compression down in the 9.1-9.5 range.
Good luck. If it works, let us know. If your machinist is an SBC guy and that's his evidence for what works, you're in deep.
He’s built servers FEs, and is also currently building a 68 S code 390 for a customers mustang. He told me the pistons aren’t completely flat, and do have some cut outs on the top. I’m sticking with the 256/262 because I’m looking for primarily low to midrange power, and optimum daily drive ability.
Quick Reply: Mild 390 build advice
