2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
New Owner - couple questions!
Old 11-18-2018, 12:36 PM
derblott
derblott is offline
derblott is starting off with a positive reputation.
Just brought home a 2019 F350 CCLB Lariat. First time diesel owner, and lurking this forum for a while helped inform my purchase decision, so thank you!
I wasnít able to find these answers in the manual or via the FTE search, but feel free to redirect if I missed something:
  1. I set my tire pressures to 55psi all around, and the TPMS is complaining the rear is too low. Iíll add more air when towing or hauling of course, but is there a way to calibrate the system so it accepts lower pressure? I have the Michelins on 20" wheels. The yellow warning light eats at my OCD...
  2. Various engine surfaces under the hood are covered in a light oily substance - pretty sure it is not motor oil. Is this some kind of anti corrosion they spray on at the factory or do I have something to be worried about?
Loving both the truck and this forum so far.
Old 11-18-2018, 02:18 PM
fortheford
fortheford is offline
fortheford is starting off with a positive reputation.
The "stuff" is sprayed on at factory and it will burn off soon enough. May smell a bit. This is normal.
For the TPMS setting, you can find out how to change that in the "FORScan" threads on this forum. Or maybe beg your local dealer but I don't think they'll cooperate. Enjoy your new truck!
Old 11-18-2018, 02:20 PM
coolidge54's Avatar
coolidge54
coolidge54 is offline
coolidge54 is starting off with a positive reputation.
My F350 CCLB Lariat 6.7 rides fine with 80psi rear, 65psi front. Just air up your tires above the warning threshold and keep it simple.
Old 11-18-2018, 04:50 PM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
On my 2015 the dealer lowered my tpms to 50 psi and turned on the def filter gauge.
Old 11-19-2018, 08:38 PM
GSDdad
GSDdad is offline
GSDdad is starting off with a positive reputation.
Discount Tire lowered my tpms when I had new tires installed
Old 11-19-2018, 09:08 PM
derblott
derblott is offline
Perfect, thank you. Just ordered my OBDII connector!
The difference in ride quality is dramatic, IMO. But more importantly thatís just the incorrect pressure for an unloaded tire - it rides up on the center and doesnít wear correctly. It was even obvious to the naked eye, the outer 1.5" of the tread on each side were squeaky clean and untouched after the drive home!
Old 11-19-2018, 09:28 PM
k7lvo's Avatar
k7lvo
k7lvo is offline
k7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to behold
I was concerned about that, too, but I just replaced the factory tires at 58,000 miles. Wear was even, tread was >4/32ís all around. Inflation was always 75-80#.
Old 11-19-2018, 09:36 PM
mattymax
mattymax is offline
mattymax is gaining momentum as a positive member of FTE.mattymax is gaining momentum as a positive member of FTE.
Any pics of the new truck ??
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
