Speed bumps shut off truck
Old 11-18-2018, 11:25 AM
RigCity's Avatar
RigCity
RigCity is offline
Went to turn on my truck this morning several relays were clicking (IDM) and lights turning on on the dash If I apply pressure on the fuse box the problem goes away. If I hit a speed bump hard the truck turns off than I’m able to turn it back on right away. (Feels like that could change how lucky can I be lol) Seems something is loose back there. I know this post seems like a great mystery hoping someone has seen this before and can provide some insight. Will be posting a YouTube video later. When the truck is on all seems fine also no engine codes present.
Thank You
Old 11-18-2018, 12:52 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
I had kinda the same issue. Truck running hit a speed bump …off. I caught the WTS light wasn’t coming on, Turned out fuse 30 under dash was very loose. I’d start by checking every single fuse for integrity-test light, then for tightness-can you wiggle or remove it with your fingers? Start with easy stuff first...
Old 11-19-2018, 10:24 AM
RigCity's Avatar
RigCity
RigCity is offline
Of course after going over a ton of speed bumps from right after posting and today the issue has disappeared. I’ll start there and see what comes up in addition to checking out the fuse #30 today.
f350rebel7788
40
09-18-2011 05:46 AM
Sheldon Plankton
19
04-10-2010 02:42 PM
alilderanged33
Electrical Systems/Wiring
04-02-2005 09:18 PM
DiGangi
1983 - 2012 Ranger & B-Series
12-12-2003 06:56 PM
carfreak113
1978 - 1996 Big Bronco
11-20-2003 07:31 PM
Quick Reply: Speed bumps shut off truck
