Zf6 clutch rod clip at the pedal - Ford Truck Enthusiasts Forums
Old 11-17-2018, 10:07 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.
Hey guys. Been busy and offline a while.
The plastic clip / bushing that holds the master cylinder rod on the clutch pedal broke. Anyway to get one without buying a clutch master cylinder or complete clutch hydraulic setup?
Tried to make a bushing and secure it with an e-clip but failed. Current plan is to order a complete setup to use the clip and have everything else as a spare. The "pin" welded to the clutch pedal has a little wear but not too bad so I don't think I need to remove the pedal to fix it.
Any ideas?
Old 11-17-2018, 10:08 PM
brandon_oma#692
Nevermind found this ford part number 6C3Z7A581A and ordered it. If it works I'll get another to keep on hand
Old 11-18-2018, 12:04 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Pm me ur address branden..i got a pack of yhem i wony need since doing a permanrnt fix..dorman has them as well
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
