1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
2003 5.4l P0171 P0174 Solved. Repair Completed
Old 05-11-2019, 09:27 PM
jbwheels
jbwheels is offline
jbwheels is starting off with a positive reputation.
I paid about $125 for the Walbro 255 kit. This is a bare pump with gaskets you have to mount in the stock sender assembly.
Walbro GCA715HP High Performance Fuel Pump Kit from Fuel-Pumps.net
I did not use it since I figured out I did not have a fuel problem.
Let me know if it's something you'd be interested in - I would not mind selling it and taking a loss vs having it collect dust in my garage forever
Old 05-13-2019, 08:18 AM
TheRed
TheRed is offline
TheRed is starting off with a positive reputation.
Thanks for the offer! I think I'd rather buy directly in town or online so I can keep an intact warranty.
Will Fuel pumps dot com allow a return?
Old 05-15-2019, 06:08 PM
maples01's Avatar
maples01
maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Originally Posted by jbwheels View Post
I know I hijacked this thread...
I finally fixed my lean codes by replacing the MAF.
Fuel trims normal now so no codes.
I had a busted intake hose, leak after MAF caused the same codes, the elbow is rubber, dryrot leads to leaks, check them first.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
