Why do I need a leveling kit?
My truck should be delivered next week, but until then I'm curious. I would assume the truck bed sits a little higher than the front when unloaded, especially since I ordered my 2019 SD with the 10K load upgrade. If I leveled it when empty then the minute I put on a load by hooking up my TT, it would sit lower than the front and I'd need to put excessive pressure on the load leveling hitch to get it back to level. What I'm expecting is that the 700-900 lbs of tongue weight will lower the rear end anyway and be somewhere close to level so I won't need as much pressure on the load leveler bars. What am I missing?
No need for one, pulling my trailer was exactly why I don’t have one, the back would then sit lower than the rear. My trailer has about 700 pounds tongue weight and sits level when it’s hooked up with the weight distribution hitch. I do also have the snow plow prep on my truck so it does sit a little bit higher in the front than a truck without it. I also like the look of a little rake on a truck.
I considered leveling mine and then decided against it. I have a TT as well with a 950 tongue weight. My concern is the same as yours. The way it sits now is dead level with minimal weight on the spring bars. My truck probably doesn't absolutely need weight distribution, but my hitch has a sway control component to it. I figure a super duty is designed to work and the truck is set up to do just that. Leveling looks awesome but it would seem to take away from the load carrying ability. But what do I know. Just my opinion.
Exactly. I like the look of the back end being slightly higher. To me it makes the truck look like it's ready to take on a load. I'd hate the look of a truck that had a sagging back end if you put anything substantial in it.
And when I do hook up a trailer or take on a load I'd rather not have the headlights point upward from that.
Ok, don't bash me on this but, I like the look of a level truck the 80% of the time i'm not hauling a heavy load, so 2 1/2 lift on the front helped a lot, But i did add Air bags to level out the rear when i tow heavy trailers. the cost for everything was less then a grand and installed myself. Love the look of a leveled truck!!!
I am of the opposite approach. I leveled my truck for more reasons then just looks. I had a Carli Back Country kit installed and also added air bags with a wireless remote, because I still use my truck as a truck and dont want it riding high when loaded. That being said the level not only improved the look of the truck imo but also significanly improved the ride, gave me more capability off road (I work in construction), and game me slight boost in water fording ability, I live in houston and it floods alot here. In addition the airbags gave me the ability to dial in the suspension no matter what I am carrying or hauling. They even help when hitching my trailers by inflating or deflating the bags I can raise or lower the back of the truck at will about 2 inch to make hitching faster. Now all of this cost more money compared to a regular spacer kit but I added to my trucks capability. I would not jump to the conclusion that everyone that levels a truck is a mall crawler. No one needs a level kit, I agree, but it can do more then just looks.
