Help marrying a t85 with a 302
Hi guys, I am trying to put a Borg Warner T85 3 speed behind my 1987 302. I installed a roller bearing pilot bearing. I checked and have no burrs. It seems like a simple process but I can't get the shaft all the way in the pilot bearing. I get the splines in the clutch but I can't get the bell housing to mate with the block. There's probably a 1/8" gap. What am I missing? Are there any tips are tricks.
Any advise is appreciated.
1969/71 F100 302 available with the optional Borg-Warner T-85N 3 speed manual with overdrive.
T85's with/without overdrive also used in 1942/48 Lincoln/Continental V12; 1948/56 Packard; 1949/51 Lincoln/Cosmopolitan; 1956 Studebaker Golden Hawk; misc Studebaker trucks; 1955/56 Hudson/Nash V8.
Hi guys thanks for getting back to me. I took it all apart and measured everything. All together there should be 1 / 8 inch extra space. I removed the bellhousing so I could see. I took it all apart. I put it together one piece at a time. It all fit. I put the bellhousing back on and reinstalled the trans. Still had a gap. Knowing it all fit I wasn't as ginger. I really jiggled it and it slid right in!
MrSki
08-30-2010 03:40 PM
jlynn8403
09-08-2009 04:16 PM
BigJake86
10-30-2004 07:15 PM
