Auto 4wd not working only manual lock in hubs - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-16-2018, 06:45 AM
Robertmbianco
Robertmbianco is offline
Robertmbianco is starting off with a positive reputation.
Went to plow for the first time this year. And my auto 4wd would not engage. No problem when i locked in hubs. Same thing happen last year, then cleared up. Any advice?
Old 11-16-2018, 07:37 AM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
I just manually lock mine when the snow starts and leave them locked all winter. Much easier.
You can get it fixed, but you really donít need to.
Old 11-16-2018, 07:40 AM
Robertmbianco
Yeah i just find it strange that it all of a sudden fixes itself, or clears up. Maybe just a clog in the vacuum? Idk
Old 11-16-2018, 07:43 AM
Robertmbianco
Kinda pisses me off though, because i would rather have the lock ins for an emergency. Otherwise why have the darn auto thing? Idk. Wish the darn 4wd's were like they used to be, back in the 70's.
Old 11-16-2018, 08:28 AM
johnfist
johnfist is offline
johnfist is starting off with a positive reputation.
Probably the vacuum solenoid not liking the temperature change. My best guess, I'm not an expert on it though.
Old 11-16-2018, 10:19 AM
Robertmbianco
Yeah just funny that this happened last year for the first storm. Then my dial, without locking the hubs, worked fine all winter. Seems like some type of blockage? Idk. Weird. I guess i'll see what happens next time. Whether i need to lock the hubs in or not. At least i have the option. I guess
Old 11-16-2018, 10:23 AM
Robertmbianco
I only use my 4wd in the winter. Never go off road anymore. My off road adventures are over now. I grew up. Unfortunately! Ha ha. Not really, just no more time for cool fidhing excursions anymore. Bummer
Old 11-16-2018, 11:33 AM
johnfist
johnfist is offline
Again, my understanding of the system is limited, but I would assume it would work like this.
Vacuum supplied to main vac line. Main vac line runs to hub, then to solenoid for actuation. If the solenoid doesn't actuate, then the wheel hub acts as a solenoid bypass. If there was a blockage, it would seem unlikely to clear during the change in seasons in my opinion, unless it was ice somehow forming in the lines. However, that would clear up once the engine compartment became heated.
I'd bet the solenoid is the problem, but someone else may know better.
Old 11-16-2018, 11:39 AM
Robertmbianco
Thanks, you could very well be right. I'll let you know what happens throughout this year. I guess I should be happy that i have the alternative to lock the hubs in and bypass that problem.
Old 11-16-2018, 02:51 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Sounds like an intermittant vacuum solenoid. Best tool for diag on this system is a vacuum gauge.
Old 11-16-2018, 03:46 PM
johnfist
johnfist is offline
FYI - the solenoids are usually easy to change, and cost around $30-$50. So, not a tough fix, nor a huge investment if the diagnoses is wrong.
Old 11-17-2018, 09:15 AM
pilotmjohnson
pilotmjohnson is offline
pilotmjohnson is starting off with a positive reputation.
I've had issues in the past with the vacuum system of my hubs. Replacing all the lines did the trick, and it was fairly cheap as well. Then again, at that time the truck has 170k and they looked original.
Old 11-17-2018, 09:55 AM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
Just lock the hubs before you leave and engage 4x4 whenever you need it.
Old 11-17-2018, 10:23 AM
pilotmjohnson
I'm curious, since I spend my winters in Breckenridge, CO, is there a speed restriction when locking the hubs and driving? I'll probably do the same since I also tow an 8k trailer even during winter, so it might make things a little less sketchy.
Old 11-17-2018, 10:25 AM
00t444e's Avatar
00t444e
00t444e is offline
No I go down the highway at 85 mph with the hubs locked no problem.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
