High idle works, EBPV doesn’t
Hello all,
Its been about a month of “cold” starts on the truck and the ebpv has yet to kick on.
In the morning the oil temp is usually around 30-40 degrees and the ambient air temp is 20-40 degrees.
Truck will go into high idle fine, and will stay in high idle until I hit the brake.
The EBPV connector is plugged in and I’m not getting any codes of it not being plugged in.
Worked last winter.
Worked last winter.
