Thinking of adding a gooseneck hitch but already have airbags
They come with four "L" brackets that bolt to the frame in front and behind the axle. You have to drill holes through the sheet metal in your bed for bolts to connect rails to "L" brackets. Kits also come with spacers to fill in the gaps in the bed so the bed rails rest firmly on the "L" brackets.
This is is just one possibility. Lot of people have airbags so there may be other possibilities.
And then welded the air bag brackets to the fifth wheel brackets. PM if you would like some pictures.
Here is a few threads I found:
https://www.thedieselstop.com/forums...-hitch-289879/
https://www.powerstrokenation.com/fo...ir-bags-3.html
Originally Posted by akcooper9
I bought these frame brackets: https://www.etrailer.com/Accessories...ese/50043.html
I figure I should close this thread out by linking to the final install post: https://www.ford-trucks.com/forums/1...l#post19657131
the_jack_82
Fifth Wheel & Gooseneck RV Towing
01-22-2008 07:48 PM
