Thinking of adding a gooseneck hitch but already have airbags
Old 11-15-2018, 12:21 PM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 2,910 Likes on 1,929 Posts
I'm thinking of adding a goosneck hitch to my truck (details in sig) but already have Firestone airbags. Are the airbag brackets going to get in the way of mounting a hitch?
Old 11-15-2018, 12:34 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Yes those will need to be moved.
Old 11-15-2018, 01:10 PM
FordTruckNoob
Argh. I was afraid of that.
Old 11-15-2018, 10:38 PM
'65Ford's Avatar
'65Ford
'65Ford is offline
I think you can have a goose ball without touching the air bags if you don't mind having rails in the bed. My truck has bed rails for a fiver hitch. I bought a goose neck adapter plate that attaches to the rails....made by Reese.
Old 11-16-2018, 04:57 AM
FordTruckNoob
'65Ford, do those rails connect to the frame? Or does the bed take all the towing loads?
Old 11-16-2018, 05:29 AM
'65Ford's Avatar
'65Ford
'65Ford is offline
They come with four "L" brackets that bolt to the frame in front and behind the axle. You have to drill holes through the sheet metal in your bed for bolts to connect rails to "L" brackets. Kits also come with spacers to fill in the gaps in the bed so the bed rails rest firmly on the "L" brackets.
This is is just one possibility. Lot of people have airbags so there may be other possibilities.
Old 11-19-2018, 05:55 AM
FordTruckNoob
Thanks '65Ford. Doing research on the various hitches now and the choices are bewildering.
Old 11-19-2018, 07:51 PM
akcooper9's Avatar
akcooper9
akcooper9 is offline
I bought these frame brackets: https://www.etrailer.com/Accessories...ese/50043.html
And then welded the air bag brackets to the fifth wheel brackets. PM if you would like some pictures.
Here is a few threads I found:
https://www.thedieselstop.com/forums...-hitch-289879/
https://www.powerstrokenation.com/fo...ir-bags-3.html
Old 11-20-2018, 05:19 AM
FordTruckNoob
Outstanding idea! PM inbound to you.
Old 03-05-2023, 05:36 AM
FordTruckNoob
I figure I should close this thread out by linking to the final install post: https://www.ford-trucks.com/forums/1...l#post19657131
wrvond
Fifth Wheel & Gooseneck RV Towing
15
01-22-2017 09:52 AM
Jace2016
2017+ Super Duty
27
10-28-2016 07:34 AM
the_jack_82
01-22-2008 07:48 PM
LaredoF350
03-11-2005 04:10 PM
sccountryboy
10-15-2003 07:28 PM
Quick Reply: Thinking of adding a gooseneck hitch but already have airbags
