Spray in Bedliner big savings
One of my recent needs was to.have a bedliner for my 2005 F 250 4x4 Superduty
i was searching eBay and found SEM products made by 3M
i found a video on YouTube and was impressed
i prepped the bed and scuffed with Scotchbrite took about 2 1/2 hours ,wiped the bed down with denatured alchohol
i released partially ,the drain valve on the bottom of the air compressor tank ,let it run for about 45 minutes before spraying
i mixed 6.5 oz of catylist in the first quart,shook for 2 minutes,the spray gun screws onto each bottle,wow ho cool that you could do as good a job as the Rhino liner and instead of the Rhino gloss version at 650.00 you could do it for 125.00
If spraying over white ,you may need a second kit, The key is check for proper coverage as you spray,Wear the best respiratory mask you have.
Last edited by Frantzjk; 11-25-2018 at 07:02 PM. Reason: Title should read DYI spray in bedline4 big savings
