H2O Heater Drain Plug Cross Threads
Received 6,624 Likes
on
on
The Atwood water heater that I have does not use an anode rod. Which may explain why I have so much crud that accumulates in the screen of my kitchen faucet. The flow was down to almost nothing, which initially made me think I had a frozen water line inside the trailer (the bathroom sink worked fine).
on
Regular flushing of the water heater will remove a lot of the lime scale. I drain mine after each trip and you wouldn't believe the crud that comes out.
There's a lot of chatter on the RV Forums about mating dissimilar metals such as brass/aluminum together causing undue corrosion. Also the smaller valve will not allow the "crud" to escape as efficiently.
I dont live in an area with hard water, our water is generally really good.
AussieDog
12-31-2001 07:47 PM
