Wrong Viscosity
This chart says it is good to -15. I go with "don't waste your money and change it at next interval."
https://www.google.com/url?sa=i&sour...42315886550811
https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahU KEwiqh4jH5NTeAhUMS60KHanXCioQjRx6BAgBEAU&url=https %3A%2F%2Fwww.machinerylubrication.com%2FRead%2F301 97%2Fchoose-engine-oil&psig=AOvVaw2ts0GvFQGiTYQiBK66yjEF&ust=15423158 86550811
That generic SAE chart states -15C (+5dF) not -15dF for 15W40. That’s a big difference.
The Ford Owner’s manual shows -7C = +20dF
I would go with the Ford engineers recommendations for their Diesel engine, not a generic table.
Is the real issue that during cold startup, cold temps mean thicker oil which means less lubrication? As soon as the trucks heats up a bit, does it make a difference? Yes, I know you then have to wait for a min or two to heat the engine up, but is a cold start up the real issue? Educate me.
Good news. Rotella has rebates on T5 15W40 and T6 5W40.
Online rebate link follows:
https://rotella.shell.com/en_us/coup...Rpb25hbDE4Lw==
I bought 4ea 3 gallon boxes of T6 from Sams Club and got $84 in rebates. 4 x $21.
You can file the rebate form online and upload receipts online. Just make sure that the receipt has the retailer name, product, date purchased and cost.
#28
#29
https://www.bobistheoilguy.com/forum...opics/535277/1
#30
15-40 oil
I live in central Ontario, Canada. I have run Rotella 15-40 in diesel pickups for over 30 years in all sorts of weather. We do get very cold weather. I routinely run 600,00 km or more and have had no problems. I do not start in cold weather and then put the pedal down right away. Give the engine a couple of minutes for fluids to warm up. No problem.
